oil questions
Old Apr 23, 2011 | 10:08 PM
BigD's Ram's Avatar
BigD's Ram
Default oil questions
I want to run synthetic oil in my truck cause when i crank it up when its cold it ticks and after it warms up it stops. My question is what weight should i run i have an 05 with the 4.7 and it has a lil over 140,000 miles on it and should i run the lucus syn in it with syn oil?
Old Apr 23, 2011 | 10:18 PM
MikeHTally's Avatar
MikeHTally
Use whatever weight the manual requires - probably 5W-20. If you live in a very cold climate, 0w-20 might be in order. BTW, synthetic probably won't quiet the tick.
Old Apr 24, 2011 | 12:51 AM
lxman1's Avatar
lxman1
Site Moderator
From what I have read, it it the timing chain tensioners and synthetic oil won't cure that or most any other ailments.
Old Apr 24, 2011 | 03:57 AM
scwpd's Avatar
scwpd
what ever it is all dodge truck motors seem to tick my 3.7l dakota did it and my hemi does it.
Old Apr 24, 2011 | 07:30 PM
BigD's Ram's Avatar
BigD's Ram
how do u change the timing chain tensioner and does it cost a lot?
Old Apr 24, 2011 | 07:40 PM
Pwall's Avatar
Pwall
the 4.7 always ticks upon start up until the oil pressure builds up
Old Apr 24, 2011 | 11:10 PM
me0418840987's Avatar
me0418840987
My 05 has been making the ticking noise since it had 60,000 miles on it. It now has 168,000. Hasn't gotten much worse. It did use to scare me when it first started, it was in winter and really cold-didn't stop for over 5 minutes. Now I just listen to it,. and it goes away when warmed up. Havent done anything to the motor other than 5 fuel injectors, and regular oil/coolant changes and maintenence. BTW, I tried both the Lucas regular additive, and the synthetic additive, and neither one made any difference. Back to running Shell rotella T 5-40 synthetic, as I run that in all of the work vehicles.
