EVIC Installed w/ odd issues
I bought the one I have (albeit for $5) from ebay that I thought was 2008 specific and it is word for word the same as your 06 version. The file even says DR2006-2008. The only ones on ebay are the print versions for $300+
So I've taken it to a second dealership.
They seemed willing to work with me if I could find out what the 'option code' was for this thing. Which, there probably isnt one since it is not a dealer option, its either in from the factory or not.
Then they told me its not possible because I don't have the modules for it like the compass and the temperature sensor being a base model truck. I KNOW that I have the temp sensor (it shows on the odometer, and even works on the EVIC when plugged in), and the compass is built into the EVIC so thats BS.
Does anyone here have access to a starscan that can look under the ECU menu to see if you can turn this feature on? If i have instructions that someone can put down, they will do it.
P.S. Is there any functionality that a starscan has without a subscription to chrysler? I know i wont get full functionality, but if I buy one and am not a dealer would it even do ANYTHING?
Seems like a pretty big pain in the butt for what's basically the equivalent of plugging in a USB device. This may seem far-fetched, but have you tried resetting the ECU after installation? Maybe a "reboot" will force the computer to take stock of what's attached to it. Probably won't do anything, but it's free, so at least worth a try.
I have disconnected the battery for 45 minutes, is there another way of 'hard resetting' the ECU?
I think you are right, it probably wont work. It IS like plugging in a USB device except that the bus is built specifically NOT to discover anything new and be plug and play. I take that back, it discovers it, but is told to ignore it until some big shot starscan says otherwise.
No one here has access to a starscan?
