37's vs stock height
Old May 23, 2011 | 11:15 AM
blackeverything's Avatar
blackeverything
Default 37's vs stock height
Alright So i have 22x10 eagles with -21 offset with 37s x 13.50
Question is will a 6inch fabtech lift kit work? what are my options i want to be able to lift it just enough so it wont rub, where it rubs is on the front fender by the door
they stick out from the fender a good 3-4 inches when mounted
Old May 23, 2011 | 03:12 PM
dirtydog's Avatar
dirtydog
Moderate User
Go HERE There is a link at the end of the very first sentence. Check that out too.
Sick wheels BTW.
Old May 23, 2011 | 03:27 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Welcome to the site
Old May 23, 2011 | 04:33 PM
HammerZ71's Avatar
HammerZ71
What year is the truck? 4x4 or 4x2?
EVERYBODY I know with the Fabtech IFS kit on torsion front 4x4s is having issues with 37s and snapping CV axles. It's a bargain basement kit and puts the CVs at bad angles. The so called 6" kit is more like 4.5-5" and requires you to get the rest of the 6" by cranking up the key bolts. VERY bad on CVs as well as a lot of other front end components. The kit does not come with bigger beefier parts like tie rod ends that hold up better to bigger tires.
Even know a LOT of guys just running 35s and have gone thru multiple CVs.
I'm not hearing it as much from coil over front end guys with Fabtech kits.
If you've got a SFA truck (2500/3500), nevermind. The solid front axle can take 37s without much issue...
Old May 23, 2011 | 05:30 PM
freestyledude's Avatar
freestyledude
I saw 8 bolts, you're good to go axle wise. 6" lift should fit 37's with ease. Careful of the cops with tires that stick out that far, that's asking for a ticket. I'd build some BF mudflaps or get some really wide flares.
Doesn't hurt to carry around a 'work order' from a shop. If the cops ask, you have an appointment booked for fender flares
Welcome to the site!
Old May 23, 2011 | 05:59 PM
HammerZ71's Avatar
HammerZ71
Good eyes - wait till you get to be my age!!!
Yeah, EVERY state has a law on the books for tires sticking outside the fenders, some states or even locales decide to enforce it, others can give a rat's a$$.
If they ticketed for it in my redneck area of Georgia, they'd have to write up about 80% of the trucks on the road, LOL...
Old May 23, 2011 | 06:50 PM
freestyledude
On a mac you can zoom in, I'm blind already! lol
It differs a lot where I am, I see a lot of guys with tires sticking way out, but if you're a teenager you can get a ticket for no mudflaps on a stock rig with A/T's.
If you're not an *** to the cop you could probably get off with a warning once
Old May 24, 2011 | 11:11 AM
blackeverything
yeah shes a 2500 4x4, what kit should i go with best bang for the buck i would like a true 6inch kit, i have heard they call some kits 6 and 8 but aren't a true 6 or 8.
the rim's have a -20 offset so when i mounted them to get an idea of how much i will rub, i got almost a half of a fully crank and the middle of the tire was hitting the out side of the wheel well down by the mudflap. Not even close so i do think it should be a true 6inch kit. so if anyone has any ideas for me pls share thanks alot guys.
wicked forum btw.
Old May 25, 2011 | 08:54 PM
freestyledude
Rancho makes good overbuilt kits, they're the best if you have the money. All the other big names aren't too bad, never heard terrible reviews about any of them
Old May 26, 2011 | 10:29 AM
Matt99's Avatar
Matt99
theres a whole bunch of different kits for SFAs. Carli kits are the pick of alot of the guys.
