Transmission not working at all.
Old May 23, 2011 | 11:21 AM
bwriteline's Avatar
bwriteline
Default Transmission not working at all.
Just a question--hoping someone can help. Changed the transmission oil and filter a few days ago and the truck was running fine. This morning, without any warning lights or other indicators, it just would not shift into gear at all. It's a 2004 Dodge Ram 2500 4X4. Any suggestions would be greatly appreciated!
Thanks,
Jose
Old May 23, 2011 | 05:29 PM
jasonw's Avatar
jasonw
Site Moderator
What is the fluid level? (You have to check it in Neutral, not Park.) You did use ATF+4, right?
I will move this to the 3rd Gen Ram section for you (2002-2008 Rams).
Old May 23, 2011 | 05:43 PM
HammerZ71's Avatar
HammerZ71
Read this thread, specifically Dirtydog's post (#8):
https://dodgeforum.com/forum/3rd-gen...blems-sos.html
Old May 23, 2011 | 05:48 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
hammer beat me to it....LOL
Old May 24, 2011 | 09:02 AM
nateroach's Avatar
nateroach
Hammer, good find. I seemed to miss that other thread entirely. Now I will know what to look for if i go the wix route for trans filters.
Nateroach
Old May 25, 2011 | 03:18 PM
bwriteline's Avatar
bwriteline
Default Thanks, all.
Truck is back up and running. It was an issue with the filter seal. Thanks again for responding.
Jose
Old May 25, 2011 | 05:55 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Woo Hoo.... I bet you are HAPPY!!
Old May 27, 2011 | 09:31 PM
Skwurlz's Avatar
Skwurlz
crap, im having this same issue after doing a drain/refill filter replacement. The really really crappy part, is I used royal Purple ATF at $12 a quart.
I'm going to go talk with the O'Rielly guys, and see if they will refund the oil cost if the filter is defective.
Old Jun 1, 2011 | 04:36 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Why not drain and save it?
Old Jun 21, 2011 | 01:38 AM
Skwurlz's Avatar
Skwurlz
Still haven't got to it yet. I thinks its slipping, and when you start it first thing in the morning and shift into drive, it takes about 15-20 seconds for it to engage. Does this after sitting for around 8 hrs.
I have a warranty, I have my reciepts for the filter and trans fluid, so I am going to wait for total failure. When they are rebuilding it, throw a valvebody and 'verter in it before it goes back together.
Truck is a SC SB Hemi Sport with a Limited slip and a 3.92 from the factory. 66,660 miles. Did the oil, filters, trans and dif fluids at 62,000 and the plugs and wires at 64,000.
