gear oil or trans oil
Old May 27, 2011 | 09:21 AM
jrd21's Avatar
jrd21
Default gear oil or trans oil
I have a 03 ram 1500 3.7 v6 5speed, It has 110,000. Was wondering if my truck needed gear oil or trans oil and how often do yall change it or have u ever changed it ?
Old May 27, 2011 | 10:34 AM
chambers's Avatar
chambers
I would have already changed both if I was you. Your manual should give you recommended intervals for your conditions, they're both easy to change.
Old May 27, 2011 | 08:58 PM
lxman1's Avatar
lxman1
Site Moderator
Most modern manual transmissions use atf. Like mentioned above, check your owners manual.
