Cant run true duals on a hemi???
Old 06-02-2011, 07:39 PM
RAM_IT_07's Avatar
RAM_IT_07
RAM_IT_07 is offline
Default Cant run true duals on a hemi???
Ok so i just bought my truck 07 4 door 4x4 and im wantint to run ture duals on it with super 44 flows dumped and my exaust shop tells me that if i do that i want have enough back psi and i will confuse my 02 sensors and make the truck run like crap anyone ever heard of this ??????
Old 06-02-2011, 07:58 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Find a new shop, a lot of guys run true dual (although I don't, I have always liked to tie in a "Y" or "X" or even an "H" pipe to equalize) and I don't personally know anyone with an issue.
Backpressure is inefficiency, plain and simple. Yes, it does move the torque curve down a little lower in the RPM range, but it doesn't improve torque at all.
What they SHOULD have advised you, if they knew their a$$ses from a hole in the ground is not to use one of the most restrictive, chambered design after-market mufflers on the planet...
Read:
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
Read:
https://dodgeforum.com/forum/3rd-gen...ml#post2514765
Old 06-02-2011, 08:29 PM
RAM_IT_07's Avatar
RAM_IT_07
Well heres whats going on the cats have just been replaced and now the 02 sensors went out ,the truck as i just found out has tru duals on it already into a dual in and dual out muffler with no x y or h pipe and there saying thats what is causing the 02 sensors to burn out !!!!! Should i get a y pipe made and do a single in dual out ???? Are just start over with 3 inch to a single in dual out to save the 02 s
Old 06-03-2011, 12:04 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
Yeah, don't worry, with Flowmasters, you will have plenty of back pressure and two mufflers that will rust away in a couple of years.
That will not have any effect of the life of an O2 sensor.
What codes are you getting? They are not burning out because of "too much exhaust flow", especially if you have cats. I think your exhaust guy is burned out.
The Muffler you have does the same thing as a x pipe pretty much since all of the exhaust meets in the muffler.
Get the actual codes and post them here and we will point you in the right direction.
Old 06-03-2011, 09:07 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Ive got duals on mine. No issues at all. However, we need to know exactly what codes the truck is getting.
Do exactly like lxman1 said.....Get the codes and please post them here and find a new mechanic or exhaust shop and hang out here with us more often.
Old 06-03-2011, 12:41 PM
HammerZ71's Avatar
HammerZ71
You sure the O2s went out or are they just popping a code due to the change in exhaust fumes? If the cats were going and you got new cats, just the cleaner air will pop a CEL due to the sudden change. Often a PCM reset is all that's required...
Old 06-03-2011, 12:50 PM
cyclone429's Avatar
cyclone429
cyclone429 is offline
Only issue you may have is retapping the 02 sensors when the Y pipe is cut out. I ran into this on my 06 2500 hemi when I went to true duals, one 02 sensor was in the Y, I did this back in 06 and I have never had issues with 02 sensors, nor any loss of back pressure ( have the 6sp man ) but I can't keep mufflers in tact.
Your only going to see payback if you tow or on the Highway a lot.
Old 06-03-2011, 06:26 PM
RAM_IT_07's Avatar
RAM_IT_07
Ok got all the exaust redone "it was a hack job" got a y pipe and 3" pipe ran to a single in dual out and had the 02 changed !!!!! And its still doing the same thing code p0430 keeps coming up and thats the converter bank 2 but there new what gives
Old 06-03-2011, 08:46 PM
HammerZ71's Avatar
HammerZ71
That's a cat inefficiency code, if it's a new cat, my bet is they have a bad weld and an exhaust leak after the pre-cat O2 and before the post cat sensor. I've done that one myself after welding on a new cat and having to work on the ground, tight space crawling under a car/truck and not getting a good bead on the blind (upward) side of the pipe...
Old 06-03-2011, 09:31 PM
RAM_IT_07's Avatar
RAM_IT_07
Well im going to the dealer tom , they put them on and its covered under the 8/80
Quick Reply: Cant run true duals on a hemi???
