rev limiter
Old Jun 5, 2011 | 04:34 PM
RAMOTTAWA's Avatar
RAMOTTAWA
Default rev limiter
is there a way to bypass the rev limiter and the gov on the trucks with out getting a chip or is it worth getting a chip just for that and what else do they really do
Old Jun 5, 2011 | 05:42 PM
SLT8's Avatar
SLT8
Not a chip but a programmer will be a very worth while investment.
There is a key cycle trick that bypasses the governor while going WOT but i don't recommend it for safety reasons and not sure if it works on all 3rd or 4G's model years.
Old Jun 5, 2011 | 07:28 PM
lxman1's Avatar
lxman1
Site Moderator
No, you need a programmer to do that. Why would you need to override the rev limiter? It is quite generous and unless you have a larger cam, you won't make enough power at the limit rpm to even need to raise it. The speed limiter I can understand. I think the default mph on my Predator is 155mph. Also, my truck is fastest when my 1-2 shift is at 5800.
Old Jun 6, 2011 | 12:30 PM
RAMOTTAWA's Avatar
RAMOTTAWA
Thw main reason why I want to know is
I want to be able to rev in park longer and for better 1\4 mile times
Old Jun 6, 2011 | 12:46 PM
RAM_IT_07's Avatar
RAM_IT_07
Please dont tell me your revin up and slaming it into gear???????
Old Jun 6, 2011 | 03:02 PM
MikeHTally's Avatar
MikeHTally
Transmissions must have gotten way cheaper. Sounds like someone needs some drag racing training.
Old Jun 6, 2011 | 05:41 PM
Blacksport's Avatar
Blacksport
Ouch!
Old Jun 6, 2011 | 07:39 PM
MikeHTally's Avatar
MikeHTally
He's gotta be pullin' our leg. Surely no one thinks a wrecked transmission and a lot of tire smoke can produce good times at the track.
Old Jun 7, 2011 | 07:17 AM
RAMOTTAWA's Avatar
RAMOTTAWA
no its mainly for the noise i have taken it to the track but i have a race car for that to me the blow by just dont sound right
Old Jun 7, 2011 | 07:33 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well as said, you need a tuner. And with an 08 you should be looking at a Superchips 3865
