trans issue continued
Old Jun 5, 2011 | 11:45 PM
devanwon's Avatar
devanwon
Default trans issue continued
ok guys so ive been fighting this trans issue, see my other post......any ways the dealer said that the computer wasnt telling the trans to shift right so they said i needed a new one.... got one and had it put in (not at the dealer and their prices, lol) anyways still same issue, the guy told me that it could be the selinoid pack, this sound right and has anyone done it on a 06 2500 with the hemi??
Old Jun 5, 2011 | 11:47 PM
devanwon's Avatar
devanwon
here is the old tread:
https://dodgeforum.com/forum/3rd-gen...-question.html
Old Jun 6, 2011 | 12:33 AM
HammerZ71's Avatar
HammerZ71
Yeah, very likely could be the shift solenoid pack, but usually a dealer will check that before they'd recommend a complete PCM swap...
Old Jun 6, 2011 | 10:31 PM
Plainbroke's Avatar
Plainbroke
selinoid pack and a new filter will make that trans seem like a new one at least it did in my sons truck..
Old Jun 6, 2011 | 11:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
Your old post, you wrote you have a hemi motor. Thats means you have a 545RFE transmission. First thing I would have done at the dealer was perform a clutch test, after that road test and verify the problem. Once the problem was verify, then remove the pan and inspect the accumulator cover on side of the valve body. Its very common for the plate to break and bend. When this does happen you will loose 3rd and 4th gears. Thats doesn't mean that is what is wrong with your truck. If the plate is not broken, then I remove the valve body and perform an air check to the clutch packs. If they are not leaking, then I would reommend a valve body assy.
Old Jun 7, 2011 | 07:53 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ Good info right there
Old Jun 30, 2011 | 12:56 AM
devanwon's Avatar
devanwon
okay a update for you guys.... tried the pcm and that was not it (the place took it back :-) ) anyways talked to my trans guy from dodge and he said he is almost certain it isnt a hardware failure or clutches in trans..... he said electrical and being as it was not the pcm that leaves the selinoid pack... got one coming should be here monday or tuesday. im gonna change that and both filters and fluid ill let you guys know soon!!
Old Jun 30, 2011 | 07:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Keep it coming....
Old Jul 9, 2011 | 11:21 PM
devanwon's Avatar
devanwon
Exclamation
got a reman seleniod pack and installed it with no luck :-( damnit!!
so what do you guys think from here, is there anything i can check myself to find out if its the trans itsself? out of luck here help please!! thanks alot guys
Old Jul 11, 2011 | 07:34 PM
devanwon's Avatar
devanwon
what do you guys think??
