Truck Uneven left to right
Old Jun 17, 2011 | 12:20 PM
RamMN's Avatar
RamMN
Default Truck Uneven left to right
I just replaced all four of my shocks with bilsteins. the front driver's side shock was leaking fluid. Now that it is all done my truck is noticably lower on the passenger side.
any ideas?
2006 ram 1500 quad cab big horn
Old Jun 17, 2011 | 09:52 PM
badblackram06's Avatar
badblackram06
maybe the shocks need to break in? I just replaced a set of shocks at work and the truck did sit uneven after the install. 3 days later the dude brought it back to get some other things put on and i remeasured it and it actually leveled out. So this may be your case.
Old Jun 18, 2011 | 02:39 AM
Caseys-dodge's Avatar
Caseys-dodge
You might need to adjust the torsion bars, but if you do that, the alignment will need to be adjusted.
Old Jun 18, 2011 | 03:11 AM
cheneymatthews's Avatar
cheneymatthews
Might take you a long time to find torsion bars in an 06.
Old Jun 18, 2011 | 04:56 AM
Denniss66's Avatar
Denniss66
if the shocks don't end up breaking in properly then your left or right spring has more give than the other if its the left sinking check it when your gas tank is empty. a buddy of mine out air bags in his truck cause he figured a full tank of fuel made his truck unlever left to right.
Old Jun 18, 2011 | 06:13 PM
MikeHTally's Avatar
MikeHTally
Shocks don't affect ride height. Only the springs do that. If one of your new shocks is absolutely frozen, that could be an issue, but it's unlikely.
Old Jun 18, 2011 | 11:46 PM
RamMN's Avatar
RamMN
Sounds good. It initially was 1.75 inches off and now it is .25 inches different. I am hoping it just needed time to settle after being on jack stands.
Old Jun 19, 2011 | 01:49 AM
JDG103's Avatar
JDG103
Old Jun 19, 2011 | 07:08 PM
Caseys-dodge
D'oh, no torsion bars? When did they stop using those? Or are they only on certain suspensions?
