fan problem.
Old Jul 21, 2011 | 01:06 PM
shorty24v's Avatar
shorty24v
Default fan problem.
I got a 2nd gen so i usually over there. But, I got a friend that has a 2003 ram 1500 and he said the fan only works sometimes and if it does only on high. I don't have all the details now but i just wanted to see if it was a known problem or something. I don't know if it happens when the heat is on but i know it does when the AC is on. Any ideas?
Old Jul 21, 2011 | 01:10 PM
Blacksport's Avatar
Blacksport
Most likely the blower motor resistor.
Old Jul 21, 2011 | 02:23 PM
shorty24v's Avatar
shorty24v
ok thanks...i'll tell him
Old Jul 21, 2011 | 03:01 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Or the ignition switch
Old Jul 21, 2011 | 03:56 PM
shorty24v's Avatar
shorty24v
is there a way to tell if either is the culprit?
Old Jul 21, 2011 | 07:13 PM
lxman1's Avatar
lxman1
Site Moderator
If high comes and goes, then I would suspect the blower, ignition switch or speed control switch. If it's just the 3 lower speeds coming and going, then the resistor block is where i would start.
Old Jul 21, 2011 | 07:14 PM
Owensue's Avatar
Owensue
If it always only works on high, it's the resistor. If it cuts in and out it could be the ignition switch.
Old Jul 21, 2011 | 08:07 PM
shorty24v's Avatar
shorty24v
ok thanks ill tell him all the info... now with this info i would be leaning toward the resistor as the problem
Old Jul 22, 2011 | 08:36 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You could try to wiggle or flip the key back and forth to see if it is the ign switch. Not 100% way to tell but might identify it
