problems drivin down the road
Old Aug 7, 2011 | 09:28 PM
dratomic's Avatar
dratomic
Default problems drivin down the road
I have. A 05 dodge ram 1500 4x4 drivin down the interstate it feels like the back end bounces down the road it has new tires they are balanaced so its not that what else could it be?
Old Aug 7, 2011 | 09:30 PM
Fav40's Avatar
Fav40
Shocks could be worn or re-check the tire balance
Old Aug 7, 2011 | 09:39 PM
dratomic's Avatar
dratomic
It happened with the tires I got on the truck and the tires now on the truck
Old Aug 7, 2011 | 09:53 PM
MikeHTally's Avatar
MikeHTally
Too much pressure, or tires out-of-round? Could be bad shocks. Are you saying there's too much vertical motion, or too busy?
Old Aug 7, 2011 | 10:09 PM
dratomic's Avatar
dratomic
Tire pressure is right where its supposed to be feels like I have a low rider car is how it bounces lol
Old Aug 7, 2011 | 10:11 PM
08HEMI1500's Avatar
08HEMI1500
Mine feels like it slides out a little bit when I hit bumps on the highway. I just figure its because my backend is so light
Old Aug 7, 2011 | 10:46 PM
dnlo613's Avatar
dnlo613
I would guarantee you need new shocks,mine used to bunny hop at the same spot on the way to work everyday till i put on some bilstien shocks a few months back and it hasn't done it since...
Old Aug 8, 2011 | 08:59 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you havent already, rotate the rear tires with the front and see what that gets you.
Old Aug 8, 2011 | 10:35 PM
dratomic's Avatar
dratomic
Already tryd that it does the same thing
Old Aug 9, 2011 | 08:52 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
So then it isnt the tires unless all four are bad. Could be the tightness on the drive shaft in the u-joint. Could be bad shocks or rotors as suggested. Last thing is a bent axle.
