Weird coolant leak
Old Aug 20, 2011 | 05:07 PM
spicoli79's Avatar
spicoli79
Default Weird coolant leak
So, I have a 2005 Dodge Ram with just over 60,000 miles on it and have noticed a strange coolant leak from the area around the water pump. However, it only leaks when I am parked in my driveway (slight incline, with front end up). When it is parked on flat ground or running, it's as dry as a bone. ???
Old Aug 20, 2011 | 06:18 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF!
Right there at the top of all the threads/posts is a thread you should read before you do anything else:
https://dodgeforum.com/forum/dodge-ra...s-section.html
I will move your thread to the 3rd gen Ram section (2002-2008 Dodge Rams).
Old Aug 21, 2011 | 11:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
there is a bead type seal around the pump. some guys have seen blown seals or pitting in the metal to cause leaks. either way, sounds like you just need to replace yours
Old Aug 21, 2011 | 01:14 PM
spicoli79's Avatar
spicoli79
So it's definitely leaking from the water pump. Parked out back of the firehouse during shift on level ground and the leak reared it's head. Looks like fun in store this week...
Old Aug 21, 2011 | 01:24 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
A new water pump doesn't cost much. Just jam a screw driver through a hole in the water pump pulley and turn the bolt on the clutch fan counter clockwise.. Our need to pull the radiator or anything else. Obviously now is a good time to change the coolant, radiator hoses and thermostat
