O2 Sensor Newbie
Old Aug 28, 2011 | 11:52 AM
WillyB1500ST's Avatar
WillyB1500ST
Default O2 Sensor Newbie
I am looking to replace my front O2 sensor(s) on my 2004 1500 3.7L v6.
I traced the exhaust from the manifold and I see on the driver side a bulge in the pipe (cat converter?) and an O2 sensor right AFTER it which would make this the back O2 sensor?
On the passenger side, I see an O2 sensor right BEFORE the bulge in the pipe (another cat converter?) which would make this the front O2 sensor?
Is this correct? Is the bulge in each side a cat conv or am I misinterpreting?
Old Aug 28, 2011 | 01:01 PM
lxman1's Avatar
lxman1
Site Moderator
Yes, the bulges are the converters. One per side. You want to replace the sensors between the engine and the converters.
Old Aug 28, 2011 | 02:12 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
1/1 O2 is front drivers O2
1/2 O2 is rear drivers O2
2/1 O2 is front pass O2
2/2 O2 is rear pass O2
Old Aug 28, 2011 | 08:30 PM
WillyB1500ST
Thanks fellas! I will hit the dealer tomorrow to get the part since some have issues with non OEM sensors from other threads I have read.
Your help is much appreciated!
Old Aug 29, 2011 | 01:04 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
be sure to report back how it works out for you.
Old Aug 29, 2011 | 05:41 PM
WillyB1500ST
I replaced the passenger side O2 sensor and now I have a hard time noticing the shudder when stopping at all!
I did however notice I do indeed have 4 sensors in all. So I got the driver side upstream sensor on order. May as well get them both done as they are way over life expectancy already.
I guess that even if they haven't "failed" yet, they can still degrade?
Old Aug 29, 2011 | 05:54 PM
HammerZ71's Avatar
HammerZ71
Yep, seen many an O2 cause performance loss (and an EGR and PCV as well) and not yet be bad enough to pop a CEL...
Old Aug 29, 2011 | 09:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
what O2 did you replace it with? price?
Old Aug 29, 2011 | 10:20 PM
WillyB1500ST
I used the dealer part 56028994AA at $70.10.
Old Aug 29, 2011 | 10:49 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
thanks
