cruse control problem
Old Sep 3, 2011 | 10:18 AM
theice's Avatar
theice
no had the truck for about 4 years and the only sensor is in the rear pumpkin
Old Sep 3, 2011 | 01:03 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Again, the sensor is on the left side spindle hub. There might be another sensor on the other side as some trucks have a them and some do not.
Old Sep 3, 2011 | 10:43 PM
lxman1's Avatar
lxman1
Site Moderator
That's the rear ABS/ Speedo sensor in the rearend.
Rock Auto shows the front sensor for your truck.
2002 DODGE RAM 1500 PICKUP 4.7L 287cid V8 FI (N) SOHC : Brake/Wheel Hub : ABS Wheel Speed Sensor
STANDARD MOTOR PRODUCTS Part # ALS104 More Information About this Part {#5083204AA}
Left Front
Right Front
AIRTEX / WELLS Part # 5S7191 More Information About this Part {#56028126AD, 56028217AC, SU8682}
RWD; Front
Part Image
* Non-stock item--shipping delayed up to 2 business days
Go to www.rockauto.com and click on the "Brake/Wheel Hub" folder, then click on "ABS Wheel Speed Sensor" Look at the pictures and then look at the back side of the driver side front hub assembly for a wire.
Old Sep 3, 2011 | 11:44 PM
wirenutjoe's Avatar
wirenutjoe
Can anyone help me on Where each connector on my 97 ram is located. Example. Haynes schematics. C226 All of these. Is there a " Map" ?
Old Sep 4, 2011 | 01:08 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
you will want to post that here
https://dodgeforum.com/forum/2nd-gen-ram-64/
Old Sep 4, 2011 | 12:17 PM
theice's Avatar
theice
when i had my friend at the dealership run my vin he said i don't have any abs sensors in the front and i looked and have no plug to plug the abs into and if the hub was replaced with one without the sensor wouldn't the abs be kicking out codes
Old Sep 6, 2011 | 11:43 PM
theice's Avatar
theice
replaced servo still no go any more ideas would be greatly appreciated
