Help Loud Squealing noise
Old Sep 1, 2011 | 12:55 AM
aca1999's Avatar
aca1999
Question Help Loud Squealing noise
2005 Dodge Ram 1500
5.8l V-8
Squealing noise when I reverse, also when I accelerate. Brakes squeal loudly when I stop. Changed Back brakes, they were bad, should I change the front as well, could this be the cause of the noise?
Old Sep 1, 2011 | 09:27 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
First, before anything else, please read this:
https://dodgeforum.com/forum/dodge-ra...s-section.html
I will move you to the 3rd Gen Ram section (2002-2008 Rams).
Old Sep 1, 2011 | 02:50 PM
rczanstke's Avatar
rczanstke
Sounds to me like your muffler bearing is bad. Jk. Yes, it would be a good idea to change the front brakes as well.
Old Sep 1, 2011 | 02:55 PM
zman17's Avatar
zman17
Retired Moderator - RIP
How come you didn't che
Never mind, let the 3rd gen guys have this one.
Old Sep 1, 2011 | 03:03 PM
drewactual's Avatar
drewactual
check for raccoons in the cab.. they can squeal.. and do it before it 'lets one fly'.. the smell can be horrific.. or, so I'm told..
Old Sep 1, 2011 | 03:08 PM
zman17's Avatar
zman17
LOL, And if that doesn't help, replace the front pads that have wear clips on them that squeal when they get worn.
Old Sep 2, 2011 | 12:45 AM
aca1999's Avatar
aca1999
Thanks everyone...I did get a good laugh...Front brake pads changed today...still squealing...sqeals when accelerating up to about 25 mph then stops...its loud? Any other ideas, Was told it sounds like a rubber squealing noise..lol I have no idea...Just want to be safer than sorry.
Old Sep 2, 2011 | 12:57 AM
Caseys-dodge's Avatar
Caseys-dodge
Does it squeal the same if you accelerate slowly versus hammering on the gas pedal? Or what about just revving the engine a little bit while in park (just to eliminate the possibility of the belt or pulley squeal). So it only squeals on acceleration only correct? If you speed up to 15 and maintain that speed would it still squeal?
Oh, just thought of something else, check the front brake dust shields to make sure they aren't touching the rotors. That happened to me last month when I put new rotors on.
Old Sep 2, 2011 | 01:28 AM
aca1999's Avatar
aca1999
ok. When I reverse slowly it only squeals a little, when I put it in drive and accelerate it squeals loudly until I hit abou 20-25mph, then no squeal and does not squeal again when stopping only accelerating,and its definately not a belt. its like a squeek squeek squeek. Thats the only way I can describe it, also told it sounds like rubber rubbing together.
Old Sep 2, 2011 | 11:38 AM
Mrose1977's Avatar
Mrose1977
Dose the squeek go away as you turn the wheel???
