What kind of differential fluid???
Old Sep 12, 2011 | 08:26 AM
ccgRAMrod's Avatar
ccgRAMrod
Default What kind of differential fluid???
OK, Im planning on changing my differential fluid before I head out to Wyoming from Wisconsin. I read that pulling a trailer that I should be running 75w-140 in both front and rear diff's. Is this true? Or should I just run the 75w-90 in both?
Also I bought the PML covers for the front and rear. Does anyone know how much more fluid they hold with this type of cover on?
Old Sep 13, 2011 | 08:33 AM
Marklorenzo's Avatar
Marklorenzo
75w90 or 75w140 both work just fine. Make sure it is a synthetic product i.e Royal Purple, Mobil 1. Synthetics have a higher temperature range. Hope this helps.
Old Sep 13, 2011 | 09:08 AM
nateroach's Avatar
nateroach
He has a 2500, so that could change things as well. Realistically you could run either weight, but if you tow at all I would recommend the 75W-140.
Stock capacities are ~2.5 qts up front and ~3 qts in back. most increased capacity pans add ~1-2 qts.
nateroach
Old Sep 13, 2011 | 11:10 AM
ccgRAMrod's Avatar
ccgRAMrod
Thanks guys. I went with the 75w-140 Royal Purple. It's what the dealer said to run as well.
Old Sep 13, 2011 | 11:29 AM
Marklorenzo
Ahh did not see he had a 2500. Good Choice on the RP. You wont be disappointed.
Old Sep 13, 2011 | 11:58 AM
HammerZ71's Avatar
HammerZ71
I run 75w-140 RP in the front, changed every 30k miles. 75w-140 Lucas conventional in the rear with their friction modifier, changed every 15k miles.
You don't need to bother with the conventional in the rear like I have to. The RP is a good choice for both. Normal use with occasional towing then 30k changes. Tow often or real heavy and change it every 15k...
Old Sep 16, 2011 | 09:29 PM
BILLS06's Avatar
BILLS06
What Dodge recommends as far as weights, they're already full synthetic. Royal Purple already has the friction modifier in it, btw.
Old Mar 28, 2013 | 04:51 PM
RamedHemi's Avatar
RamedHemi
Default 2008 ram 1500 4x4
I have a 2008 1500 4x4, is ok if I run 75W90 in front and rear? Ill prob go with royal purple seems to be the best choice...
Old Mar 28, 2013 | 05:23 PM
ccgRAMrod's Avatar
ccgRAMrod
yes that should be fine. otherwise call your local dodge service center and ask them. go synthetic.
