Dodge Ram 1500 4x4 4.7L Code P0480
Old Oct 24, 2011 | 10:07 AM
mcwwaldo's Avatar
mcwwaldo
Default Dodge Ram 1500 4x4 4.7L Code P0480
Ok. This damn code is driving me crazy!!!! I jumped the electric fan motor and it is working. I reset the cpu with the cpu diagnostic tool to clear the code and the code keeps coming up. I disconnected the battery, the code still comes up. I do not think I have a relay for the fan...can't find one in the fuse box. I called the dealer and they said they have NEVER had to replace the Coolant Temp. Sensor on a 4.7 L engine ever. They said it might be the Computer (which I doubt) Can anyone HELP?????? PLEASE?????????
The only other thing I think it could be is the sensor that sits in front of the ac radiator (coolant temp sensor)
And my ac does work, but when the engine heats up, it keeps shutting off because the darn electric fan is not working!!!!
AAAAAAAAAAAA!!!!!
Old Oct 24, 2011 | 12:57 PM
vpnavy's Avatar
vpnavy
Welcome Aboard mcwwaldo! Stay tuned - a Technician (or member) will jump in shortly to provide a possible solution. In the meantime, don't forget to browse Sub-Forums: Ram for stuff related to your ride.
Old Oct 24, 2011 | 08:48 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Welcome to Dodge Forum!! Enjoy the site!!
Dusty
Old Oct 24, 2011 | 11:52 PM
master tech's Avatar
master tech
Site Moderator & Tech
There is a fuse I think it cav 39 in the PDC/IPM for the a/c fan. If the fuse keeps blowing then you need to replace the fan.
Old Oct 25, 2011 | 05:38 AM
mcwwaldo's Avatar
mcwwaldo
I bought a coolant temp sensor and an ambient air temp sensor. I am installing them today. I will check on the fuse too. Thanks I will post later this evening.
Old Oct 26, 2011 | 06:23 AM
mcwwaldo's Avatar
mcwwaldo
I installed the coolant temp sensor and the ambient air temp sensor and reset the cpu and the light is still on. The book says it might be the powertrain control module. Well I doubt it is the cpu....what now??????????? I am going to check the grounds....any help?????
Old Oct 27, 2011 | 12:33 AM
master tech
Did you check all the fuses in the PDC? Either use a 12 volt test light or DVOM.
