Lowering Shackles
Old Oct 24, 2011 | 11:08 PM
TheZunk's Avatar
TheZunk
Question Lowering Shackles
New to the forum, first post. I have searched high and low for a pic based diy for rear shackles other than the GM one. I have a 2007 quad ram 1500 2wd and want to level the rear. I plan on using McGaughys #44002 2" shackles on factory rims/tires. Based upon the suspension exploded view in a LMC Truck catalog, it looks easy to do. Any input? Not sure how to move reply, realized I posted in the dakota forum. Sorry
Old Oct 25, 2011 | 05:30 PM
what do you drive and I can get this to the proper sub section. But, the install is going to be pretty much the same on any leaf sprung rear end. The key is jacking up the rear end from the pumpkin and then loading/unloading the springs to get the bolts out.
Old Oct 25, 2011 | 07:26 PM
Oh nevermind. Just re read your post.
Old Oct 25, 2011 | 07:56 PM
TheZunk's Avatar
TheZunk
2007 Ram 1500 Quad Cab 2wd.. Thanks
Old Oct 26, 2011 | 06:33 PM
Caseys-dodge's Avatar
Caseys-dodge
Check out this post in our DIY section, it's got some good pics and should be some help to your project.
https://dodgeforum.com/forum/3rd-gen...e-install.html
Old Oct 26, 2011 | 11:39 PM
TheZunk's Avatar
TheZunk
Sweet, thanks. Seems pretty straight forward for the rear shackles. What about removing the overload spring? Any info? Not sure where or which, or even how.
Old Oct 27, 2011 | 05:05 AM
Brandon Anderson's Avatar
Brandon Anderson
Yeah, the shackles are pretty easy to do, although the stock ones are already pretty dang short. They make a 2" lowering shackle for the '06+ RAMS?
I don't believe there is an overload spring on our 1500s, unless someone added an aftermarket one to yours.
Old Oct 27, 2011 | 12:56 PM
TheZunk's Avatar
TheZunk
I looked on their site and found 2" shackles for the '02-'08 part# 44002 Hope I'm seeing what I think I see.....lol Not sure about the overload spring, maybe other users can add....?
Old Oct 27, 2011 | 01:12 PM
TheZunk's Avatar
TheZunk
Found some info on the overloads, not sure I wanna go there....
https://dodgeforum.com/forum/3rd-gen...f-springs.html
Old Oct 27, 2011 | 02:40 PM
bgbluram2's Avatar
bgbluram2
Yes there is a 2" drop shackle for our 06+ rams. I have them on my truck. Our 1500's also DO come with an overload spring which I removed to give an extra 3/4" drop in the rear. The truck is just about perfectly level. The shackle is very easy to do. All you need is a couple jack stands and a jack, 1/2" breaker bar to get the nuts loose, and an impact gun makes the job that much faster if you have one. Took me about 45 minutes to do the shackles. Removing the overload spring is a little more involved, but not too bad. Give yourself a couple of hours for that though.
