Hard starting except first start of day; fuel smell
I have perused the threads and everything seems to point to cleaning/replacing the EGR valve first to start. I want to confirm with all my symptoms before I do that even though I probably will do it anyway seeing as there are 61,000 miles on the truck.
Truck is a 2005 RAM 1500 with 5.7L Hemi purchased in 2006. Prior to deploying to Iraq in 2006, the engine would be difficult to start after the initial start of the day. Sometimes CEL came on but would go back off. While I was deployed my wife had the pleasure of convincing the Dodge dealership something was wrong (considering still under warranty!). Cleaned throttle body, no codes were stored in CEL. Finally when light came back on she took it immediately in and they diagnosed EGR. They replaced in accordance with the warranty.
Fast forward to 2011. Truck has the same problems. It will turn over like a new truck first thing in the morning or if stopped for a quick run into a store and back out. However, if it sits for any length of time in between (other than overnight!) it takes a lot of cussing to get it started. Not really but you get the idea. It does start. There is a strong smell of unburnt fuel after this happens.
My plan is to first remove and clean the EGR. I guess I should ask: If this doesn't work should I invest the $39.99 at Autozone to buy a new one? If cleaning/replacing the EGR fails to fix the problem what sensor/component should I look at next?
Thanks!
Ed
now the DodgeRetiredArmyGuy, well since 2009.
Thanks!
Ed
Trending Topics
Thanks. I did clean the throttle body on one side. I didn't remove it completely though and I should have when I did the spark plugs last weekend. I did remove the EGR valve today and clean it then put it back on. Getting ready to take it for a ride and see what happens.
I reinstalled the EGR after soaking it in cleaner for a few hours and using a bottle brush to clean the inside. It didn't work it appears as the truck is still hard to start after it has ran for a bit or the day. My next step is to buy a new EGR valve and try that. @SBSGA - Yes it happens everyday. It does not happen the first start of the day. It is as I described in my original post.
If your motor is cold & flooded it will start, hot &flooded it will need to turn over to clear the unspent gas. Spend a little $ on 1 injector & swap out each until you find the bad 1.
