I need help please!!!!!
Old Dec 10, 2011 | 08:12 PM
Steve/06 Hemi's Avatar
Steve/06 Hemi
Default I need help please!!!!!
Ok so i'm trying to order some new rims(wheels) and there's ALOT of different options as far as offset/backspacing. I know that the lug pattern is 5x5.5 I think the backspacing that i want is 4.5 but what's got me a little confused is the offset. I think what i want is -12 Could somebody who knows help me out here? I have a 2006 RAM 2WD/ and the rims i'm looking at are XD Monsters 18x9 also i don't have any lift or level but wanted to do a 275 or 285 70/18 any help would be greatly appreciated don't want to order the wrong ones.
Old Dec 10, 2011 | 09:09 PM
Steve/06 Hemi
Oh man i've been doing more research now i'm even more confused. Now i think i need the 5.5 backspacing and a +18 offset. I don't want the tires to stick out very far at all.I want them as close to stock as i can.
Old Dec 10, 2011 | 09:43 PM
boosted-fc3s's Avatar
boosted-fc3s
This may help:
http://www.1010tires.com/wheeloffsetcalculator.asp
Old Dec 10, 2011 | 09:44 PM
MikeHTally's Avatar
MikeHTally
My DC-1s are 4.53" backspace and -12mm offset. I'm not sure 5 1/2" and +18mm will fit. Positive offset pulls the wheel in, negative pushes it out. Pulling in and increasing the backspace would not seem a good idea. Try 1010tires.com
Old Dec 10, 2011 | 10:17 PM
Steve/06 Hemi
Thanks checking it out. I'm just trying to get it right cause i want to order them online and not have to go through the hassle of returning them. It's just i have read SOOOOO many posts about what size wheels people put on there trucks that my brain is bleeding out my ears. Mike how did your set up turn out?
Old Dec 11, 2011 | 11:32 AM
Steve/06 Hemi
Old Dec 11, 2011 | 12:22 PM
MikeHTally's Avatar
MikeHTally
Mine are good - They do stick out a bit too far for me, but a set of flares will take care of that.
Old Dec 11, 2011 | 04:47 PM
Dudemanbrother's Avatar
Dudemanbrother
Stock is +20mm offset so get the +18s and they sit nice and flush. I put the monsters on my truck and they don't poke at all.
Old Dec 11, 2011 | 04:56 PM
Dudemanbrother
If your truck has factory 20s they have 33" tires so you should be fine with 275/70/18. The 285s are barely wider and taller. Take the mm divided by 25.4 to convert to inches. You can turn your wheels full lock inward and measure your space in inches and multiply by 25.4 to get the widest possible tires, but honestly 275 should look great and not cause any problems.
Old Dec 11, 2011 | 07:00 PM
Steve/06 Hemi
Thanks Dude for the info.What was the backspacing you went with? I'm thinking the 5.71 is one the Monsters come in that is closest to stock.Oh and the stock 20's are 32.99" and the 285 70 18's are 33.71" is that too much ya think without a level? The 275 70 18's are 33.16.
