3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Im thinking it might be more of the ball joints because when im standing still and i turn the wheel a little bit i hear the squeeking. I would be replacing just the lower correct?
pl4, also check your front axle ujoints, when they start to fail they sometimes dry out, start to sceize and will squeek. If you jack the front end up turn the steering wheel then rotate the tire you should either hear and/or feel it. Just throwing that in the mix.
Good luck
