Transfer Case Shift Arm fell off? If so, this might help you.
Old Jul 25, 2012 | 01:18 PM
DodgeBluto's Avatar
DodgeBluto
Originally Posted by Kalten
Would it not have made a better installation to use Heim joints to make the linkage? that way you could tighten it down all the way and even place a rubber boot over it to keep moisture out, may cost a bit more though. It is a good fix either way.
http://www.mcmaster.com/#ball-joint-rod-ends/=ijvhrf
Those are pretty slick. I think my local Tractor Supply has those.
Thanks PireFyro, this is a nice little upgrade to avoid crawling under the truck on a cold snowy day.
Old Jul 25, 2012 | 04:05 PM
pirefyro's Avatar
pirefyro
That probably would work better. I didn't see any at lowe's though.
Old Dec 16, 2012 | 05:35 PM
fireman3589's Avatar
fireman3589
Thank you for the fix. I just found mine missing at deer camp trying to put it in 4WD. I crawled under the truck to find part of a plastic bushing on the shifter arm. I was not looking forward to going to the dealership. This will be a much better fix.
Old Dec 16, 2012 | 05:40 PM
fireman3589
Much easier than making one!
Old Dec 18, 2012 | 12:03 PM
pirefyro's Avatar
pirefyro
Default Almost one year later...
Good news for anybody who has tried this fix. Mine has no rust on it after almost one year of installation, no issues with the aluminum threads being smoothed over by the steel bolts, and all places where the bolts could've moved have not. I may upload a picture of it when a year does pass, but no real need since it still looks the same. If any of you tried this, I hope it helped you out.
Old Dec 19, 2012 | 06:45 AM
fireman3589
Worked great, very easy to do, went on without a hitch. Lowe's sold out of the 5/8 SAE washers. Who would have thought that they would end up being so hard to find. I went to Home Depot and Tractor Supply, and nothing. I used the 16m metric washers. They seemed to be the same size OD and fit over the spacer.
Old Dec 19, 2012 | 08:32 AM
kamicrazy99's Avatar
kamicrazy99
Awesome idea, thanks!
Old Sep 4, 2013 | 08:27 PM
feeney.jayson's Avatar
feeney.jayson
Just did the install on my truck. Worked out great!
Old Nov 21, 2013 | 11:18 PM
pedrugge's Avatar
pedrugge
Even if it rusts, it's only going to get tighter. Once the assembly is complete and adjusted, you should never have to mess with it again. The other fittings you suggest are probably not long enough.
Old Dec 2, 2013 | 12:22 PM
gitndrift's Avatar
gitndrift
Great write up. Thanks for the idea. Everything worked good for me. Only thing is noticed the turnbuckle can move freely right now though so I'll have to go back and get jam nuts.
