2002 Ram with 5.9l gas wont start.
Old Jan 24, 2012 | 12:35 PM
gtup's Avatar
gtup
How do you take the IAC off? It looks like it hidden behind the throttle body and would be hard to get a screw driver back there...
I got a new battery I will be putting in the truck when I get home but if that doesnt work I will need to take that off and clean it.
Old Jan 24, 2012 | 02:23 PM
drewactual's Avatar
drewactual
taking the TB off is by far the easiest option..
Old Jan 24, 2012 | 02:49 PM
gtup's Avatar
gtup
Could the ECU lost its memory? I did have to jump my truck to get it going, maybe the ECU lost its memory because of the dead battery?
Old Jan 24, 2012 | 02:54 PM
Blacksport's Avatar
Blacksport
Doesn't the ECU have it's own battery?
Old Jan 24, 2012 | 03:34 PM
HammerZ71's Avatar
HammerZ71
Ahhhhh, now we get more information. Put your new battery in and go from there. Odds are - your problems will be solved... Now I'm leaning even more toward my original assessment...
Old Jan 24, 2012 | 06:54 PM
MadManser's Avatar
MadManser
I too have had the exact same issue on a jeep 4.7l i had. battery died jumped it would only run with my foot on the gas. Replaced battery cruised her around for 15 min solved the problem.
Old Jan 24, 2012 | 09:18 PM
miller2josh's Avatar
miller2josh
also.. these trucks do not have a fuel filter.. its integrated into the fuel pressure regulator.. which sits on top of the tank near fuel pump.. usually never goes bad.. but i agree.. sounds to be a battery issue.. had a similar issue with my old 02.
Old Jan 25, 2012 | 07:03 AM
gtup's Avatar
gtup
Put a new battery in the truck and after a two cranks it started right up. My battery must have been shot but it still had 12v to it. Im just glad its up and running again, thanks for your help guys.
Old Jan 25, 2012 | 09:14 AM
HammerZ71's Avatar
HammerZ71
Measuring 12v doesn't mean sh*t, I had a battery measured a perfect 12v but had it tested and the 750 CCA when new battery had 61 CCA according the Advance Auto...
Old Jan 25, 2012 | 09:34 AM
gkperformance's Avatar
gkperformance
Glad you got it going!
