Hemi hat removal...
Old Feb 13, 2012 | 04:45 PM
jbird720's Avatar
jbird720
Default Hemi hat removal...
Someone mentioned removing theirs in another post.
What are the pros and cons of doing this?
Also what are the appropriate steps to remove and replace with??
Thanks
Old Feb 13, 2012 | 04:56 PM
extremis's Avatar
extremis
Pro - Smoother airflow from filter to intake
Pro - You may gain a horse power or 2 at wide open throttle
Pro - its gives a bit easier access to spark plugs (since to change plugs you have to take the hemi hat off anyways).
cons - increased intake noise
Most people replace it when they purchase a cold air intake system. I looked at my hemi hat, and it's not that bad. It had a curved air path, with some smaller holes off to the sides to dampen noise (acting like a muffler).
Its fairly easy to remove, a few bolts, the air pipe clamps and hoses. You can replace it with tubes from ebay, plumbing pvc pipe or purchased cold air intake kits. When you replace it, you need to relocate the inlet air temperature sensor into the new pipe.
If you search for cold air intake on here, you can see some of what people have done. Especially if you select the DIY posts.
I don't think there is much for Pro/Cons that really says do it or not. If it can be done cheaply, it makes a nice mod. If you do a good job of it, it looks nicer under the hood. Some guys have really dressed them up and it looks great. Performance wise, unless you run at full throttle the gains are minimal by itself, and only a few horse power more with the cold air intake.
Old Feb 13, 2012 | 09:27 PM
pitbull24's Avatar
pitbull24
One of those mods that leads to another and another.....
Replace Hemi hat with CAI, then TB, then Exhaust. If you do one you better do 'em all.
Old Feb 13, 2012 | 09:33 PM
SLT8's Avatar
SLT8
More engine noise is what i first noticed. Also as mentioned you have more access to the plugs etc.
Old Feb 13, 2012 | 09:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Took mine off so long ago I forgot what it looked like. Get rid of it and get a GOOD cold air intake. Dont get anything made of metal. I have plastic welded some together and they work great but do stay away from metals ones.
Old Feb 13, 2012 | 11:18 PM
redneckhemi's Avatar
redneckhemi
I just took mine off tonight and ended up with this
Still gotta do some touch up painting but it gets the job done and total cost is around 65 bucks.
Old Feb 14, 2012 | 03:36 AM
abarmby's Avatar
abarmby
Don't forget to the OP....if you fit an aftermarket CAI, there are many post's of people hydro locking and destroying engines when fording water holes and puddle jumping etc.
Just bear that in mind when you "play" and you should be OK.
Al.
Old Feb 14, 2012 | 03:48 AM
Arctodus's Avatar
Arctodus
Hey Weed, why should we stay away from metal?
Old Feb 14, 2012 | 04:35 AM
dirtballer's Avatar
dirtballer
Because metal will get hot and the hemi like's cold air not hot lol.
Old Feb 14, 2012 | 04:38 AM
dirtballer's Avatar
dirtballer
I took mine off but did not like all the nosie. You can make you own pretty cheap.
