Last edit by: IB Advertising
Browse all: Specifications & General Maintenance
- Dodge Ram 2002-2008: How to Program Garage Door Opener
Step by step instructions for the do-it-yourself repairs
Programming Garage Door Opener
HELP. I've gone round and round
and cannot get my Homelink to sync up with my garage door opener. I've read the manual, tried the Canadian version, and the Homelink even signals like it has been correctly programmed but it still doesn't open my garage door. Anybody have any input for me?
Thanks
Thanks
Thanks
Thanks
Note: Some vehicles may require the ignition be turned on or the vehicle actually running to program the Homelink® transceiver.
To program a rolling code compatible Homelink® system, please follow these steps.
1. Press and hold the two outside buttons on the Homelink® system until the LED starts to blink, release buttons
2. Press and hold the desired Homelink® button and the transmit button on your rolling code transmitter at the same time until the Homelink® LED changes from a slow blink to a rapid blink. (Your Homelink® system is now programmed)
3. Locate the learn code button on your garage door opener. (These are located under the light cover or on the rear panel depending on model)
4. Press the learn code button on the garage door opener, a red LED will start to blink. (You will have 30 seconds to complete programming)
5. While the LED on the garage door opener is blinking, return to the vehicle and press the pre-programmed Homelink® button 4 times. (Or until the garage door operates).
To program my new remotes I used this instructions: http://wnet.name/content/visor_compact_prog.html. On the garage door opener itself, there should be a button that is marked, "Train" or "Learn" or something similar. Press that button. You will then have 30 seconds to get into your car and press the Homelink button you wish to program twice. That should program the Homelink button to your garage door. I just did this tonight, and it worked on both my Highlander and my G35. FWIW, there are simple instructions in the Highlander manual. They are much less convoluted than the Infiniti instructions.
Trending Topics
Just a side note. The other two HomeLink buttons nobody ever uses make great switches for things like off-road lights when paired with an inexpensive wireless relay. Been doing this for years. I HATE DRILLING/CUTTING THE DASH FOR SWITCHES...
