Getting oil everywhere when changing filter?
Old Apr 4, 2012 | 07:41 PM
Dave M's Avatar
Dave M
Default Getting oil everywhere when changing filter?
2007 Hemi. Is there any way to change the oil filter without taking a bath in oil? I get oil all down my arm, it pours down over the steering rod and runs along that in every direction, and it practically shot out all over the driveway. I have cardboard down but it shot over the cardboard! It just gets everywhere. Is there something I'm doing wrong?
Old Apr 4, 2012 | 07:51 PM
Kscha41's Avatar
Kscha41
Well once you break the filter loose you can slip over a zip-lock baggie over the filter and all the oil should go in the bag.
Old Apr 4, 2012 | 07:59 PM
Dave M's Avatar
Dave M
That's a good suggestion. I'll try that next time! I knew there had to be a simple solution.
Old Apr 4, 2012 | 08:57 PM
NV290's Avatar
NV290
I have the same issue. Poor design having the filter directly above the steering unit, but then again, not too many ways to fix the issue at the factory short of using a remote oil filter setup. Which i have considered adding.
I take a 10-20 page newspaper and drape it over the steering unit with the crease on top. This way when the oil starts coming out, it will not get on the sterring unit or crossmember. Just on the cardboard and newspaper.
Old Apr 4, 2012 | 11:19 PM
MikeHTally's Avatar
MikeHTally
I use a windshield washer bottle with the bottom cut out. Slip it over the filter and spin 'er loose. The filter drops into the bottle - no muss, no fuss.
Old Apr 4, 2012 | 11:21 PM
07Chuck's Avatar
07Chuck
I have only done mine once but next time I'm just going to take a smaller pubch/chizzle pound it in then either put a small pan or get lucky and the small stream will clear the steering ect when you remove it depending where you pound it in
Old Apr 4, 2012 | 11:52 PM
boosted-fc3s's Avatar
boosted-fc3s
There's no way to rig up a drain tray like the 4.7 has?
Old Apr 5, 2012 | 06:51 AM
Dave M's Avatar
Dave M
On any car you get some oil coming out when you break the filter loose. Usually a small amount that I would contain with just a rag over the filter while im unscrewing it. But with This truck the amount of oil that come out is crazy. I had a big wad of paper towels all balled up under the filter and it soaked thru the towels. It seems like a 1/4 of a quart comes out!
Old Apr 5, 2012 | 08:31 AM
RailroadMan's Avatar
RailroadMan
Search Mopar Part # 53021610AE
Oil Filter Relocation Kit
Old Apr 5, 2012 | 02:55 PM
DodgeCares's Avatar
DodgeCares
All,
The part number is now 53021610AF and fits model years 2003-2008
