K&n cold air intake question
Old Apr 22, 2012 | 09:59 AM
V8madness's Avatar
V8madness
Default K&n cold air intake question
I installed my intake the other day (black tube) and where the air sensor goes I wasn't able to push it all the way in that rubber groumet. It looks like it should Atleast push to where that rubber o-ring was but I couldn't make it go that far. Does anyone know if it's suppose to go that far and maybe I'm just having a hard time with mine? Maybe a close up clear picture of your setup would be appreciated.
Old Apr 22, 2012 | 07:36 PM
V8madness's Avatar
V8madness
Just noticed today my gas mileage is going down and down. Already lost 1mpg. Could this be from the k&n intake? It wasn't brand new when I got it but I cleaned it up and cleaned and recharged the filter.
Old Apr 22, 2012 | 07:45 PM
kenneymc's Avatar
kenneymc
Same thing on mine, sensor does not go in all the way to where oring was.
Old Apr 22, 2012 | 09:40 PM
NV290's Avatar
NV290
What brand of intake is it? I know you mentioned K&N but their are quite a few companies who make aftermarket intakes that use K&N filters. I put an Airaid induction tube on my truck and i had to push the IAT sensor in through the grommet. It will fit, just twist it while your installing it.
If the sensor is not inserted far enough, it might not give proper readings on the air temp and in turn impact your MPG. Keep in mind, an aftermarket intake will NOT increase your MPG in any way.
Old Apr 22, 2012 | 11:28 PM
V8madness's Avatar
V8madness
It's the k&n 57-1533 and I know it shouldn't increase mpg but it also shouldn't decrease it like it is. I'll attempt to pry the sensor in but I'm not certain if that's what's causing my drop in mpg or not. This didn't start happening till 2 days after I put the intake on. That's when I noticed it on my overhead display. It started out today at 11.2 by the time I was done driving for the day it's down to 10.8. No out of the ordinary driving was done.
Old Apr 23, 2012 | 10:08 AM
NV290's Avatar
NV290
What year and engine is your truck? While that overhead display is typically very innaccurate, those numbers are horrible. Even if i have a heavy foot around town, i still show close to 15 MPG on the overhead display.
And as for it taking a day or two to show lower MPG's, remember, that display is showing an average MPG, not the exact real time data. So if you did a mod that will hurt MPG's, it will take time for the numbers to start to drop. So it makes sense.
Old Apr 23, 2012 | 10:31 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Keep in mind you did a CAI to get more air inside the engine and to make more power. More power meas more fuel which means less MPG
Old Apr 24, 2012 | 09:12 AM
xtremedurb00's Avatar
xtremedurb00
I had the same problem with my intake...I had to take a razor and trim up the hole a little bit. After some twisting and a few cut fingers later, I was able to get it in all the way. It should go in all the way to the shoulder. About your MPG...everytime you do a engine mod, you'll lose some MPGs because of the automatic heavy foot. Mine seemed to drop a little bit at first too. I've had mine on for about a month and now my MPG average is about 1.5 higher than what it was before the intake. I don't use the overhead. I just average it after every fill up. You'll see alot more power and MPGs whenever you get a tuner if you can make yourself stay out of the throttle.
