4.10 or 4.56 for towing??????
Old Apr 22, 2012 | 02:48 PM
jj141979's Avatar
jj141979
Default 4.10 or 4.56 for towing??????
I have a 2003 Ram Hemi 4x4 QC with 3.55 gears. I will be towing around 7000lbs when I do tow. I wanna change my gears for better towing performance. Which is better for all around towing, 4.10 or 4.56???? I am also wanting to get a limited slip differential. What is the best limited slip differential for towing?????
Old Apr 22, 2012 | 03:51 PM
boosted-fc3s's Avatar
boosted-fc3s
What size tires are you running? 17" wheels with a 35" tire makes 4.56s just about ideal.
Old Apr 22, 2012 | 03:53 PM
hillbilli's Avatar
hillbilli
Go with the 4.56 and you wont regret it. It will keep you in your rpm's in the power band and youll barely know your pulling. I dont know any brands but i know theres a few out there.
Old Apr 22, 2012 | 04:05 PM
jj141979's Avatar
jj141979
Stock wheel and tire size 265/70-17. I may goto 285/70-17 when my current tires die.
Old Apr 22, 2012 | 04:13 PM
JSE414's Avatar
JSE414
I run a 285/70/17 and its perfect for stock ride height. As far the gear. I highly recommend 4.56 Auburn LSD.
Old Apr 22, 2012 | 08:43 PM
p38251's Avatar
p38251
I have the same size tires I went with 4.56 I tow 8500 travel trailer. go with 4.56 you won't be disapointed. I don't have a limited slip. didn't fell it necessary for towing.
Old Apr 23, 2012 | 01:00 PM
extremis's Avatar
extremis
My megacab 2500 has factory 4.10's. With the Hemi, it pulls my RV nicely. Granted, mine is only 5000lbs or so, + an atv in the truck bed (another 700lbs). Its also a heavier truck.No complaints in the mountains. Your truck is rated already to tow 7000lbs. You'll be happy with either gear set I think. Your no load driving fuel mileage will become even worse than it is now though. Might be a bit better in town, but highway will suffer.
Old Apr 23, 2012 | 10:25 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I run 456s with my 16ft trailer and no regrets or complaints at all
Old Apr 24, 2012 | 09:27 AM
xtremedurb00's Avatar
xtremedurb00
I can't wait to get the auburn and 4.56s for mine.
