Trans temp increase
Old Apr 26, 2012 | 06:51 PM
Deroneill's Avatar
Deroneill
Default Trans temp increase
I've noticed since i've done some mod's (custom cam, LT Headers, performance heads, etc...) my trans runs a little hotter than usual. About 20-30 degrees. Is this normal? I drove it for about 100 miles the other day and it was fine but i'm just curious.
Old Apr 28, 2012 | 01:04 PM
HemiLonestar's Avatar
HemiLonestar
Your engine is working harder, which will transmit heat to your transmission. A bigger trans cooler will help, especially if/when you put a bigger converter in it.
Old Apr 30, 2012 | 04:39 PM
Deroneill's Avatar
Deroneill
So will i be ok without a bigger trans cooler and/or converter? or should i put either one in. Its not a daily driver and probably about 20% track and 80% street
Old Apr 30, 2012 | 07:32 PM
p38251's Avatar
p38251
bigger trans cooler is cheap insurance. that 20-30 deg is also heating trans fluid up as well.
Old May 2, 2012 | 08:33 AM
Deroneill's Avatar
Deroneill
Yea I can see the trans temp on my interceptor which is how I knew it runs a little hotter than before. It only does it when I'm driving around town it gets up to about 195. When I'm on the highway it stays at around 160. Where can I get a bigger trams cooler?
Old May 2, 2012 | 09:16 AM
dirtydog's Avatar
dirtydog
Moderate User
How many miles on your fluid? As the fluid gets older it won't dissapate the heat as good and it will actually heat up faster because the molcules are producing more friction. This is why old trans fluid becomes burnt smelling.
Maybe a fresh flush is needed? I'm going to make a non-invasive flush procedure for the FAQ section for everyone since this comes up alot.
HERE you go. I'll update it as needed if there are any issues with it.
Old May 2, 2012 | 02:50 PM
Rich 2500's Avatar
Rich 2500
That does not sound kosher to me, make sure you didn't kink or bend a cooler line or have it against the header. Technically the Trans. does not give a rats *** what the engine is doing, if you're driving it with the same type of loads on it, as before the mods, it should not effect the tranny temps.
Old May 2, 2012 | 05:12 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Some guys also use a deeper trans pan to keep the oil cool
Old May 3, 2012 | 09:21 AM
Deroneill's Avatar
Deroneill
When i replaced the headlight the other day i did notice one of the cooler lines looked a bit dirty at the connection to the cooler like its been leaking a bit and a bunch of dirt got stuck to it. maybe thats the culprit. But yea i only have about 15,000 miles on the trans fluid. when i get the chance im gonna check it out more.
Old May 4, 2012 | 09:38 PM
pitbull24's Avatar
pitbull24
195 seems a little high, def try to figure it out.
