My fan is always working!
Old May 1, 2012 | 10:12 AM
OhFive_Daytona's Avatar
OhFive_Daytona
Default My fan is always working!
I got this truck a couple of weeks ago, and I've got ONE complaint and don't want to drop my truck at the dealer's service department for 3 days on something that's probably simple... So my heat/AC (fan) is constantly blowing very gently when the *** is clearly all the way left and OFF. It works fine when I turn it on, blowing harder with each notch I turn the ***, but no matter what it's always blowing at least a little. Any advice or suggestions to the problem?
Old May 1, 2012 | 10:38 AM
millero's Avatar
millero
Does it blow even when the truck is sitting still?
Old May 1, 2012 | 12:22 PM
OhFive_Daytona
I haven't checked that, I'm pretty sure it blows whenever the truck is running, both idling and at speed. I always turn it to the feet setting when I'm done using it because I can't feel it through my jeans. I get off work at 3, so I'll check it when it's sitting still before I leave.
Old May 1, 2012 | 04:01 PM
OhFive_Daytona
Okay, so it doesn't blow when the truck is just sitting at an idle. But maybe it wasn't blowing the whole way home? I didnt check because it's blowing more often than not.
Old May 1, 2012 | 05:28 PM
Gone Fishin's Avatar
Gone Fishin
Put the air control on recirc and see if the air is moving while you're driving, you may be feeling air coming in from outside without the fan actually running.
Old May 2, 2012 | 08:11 AM
millero's Avatar
millero
air comes through the vents while the vehicle is moving when the ac/fan is off.
Old May 2, 2012 | 08:49 AM
OhFive_Daytona
So I payed more attention this morning, and I don't just feel the air, I can hear it. It sounds like a little motor is running. I'm stumped.
Old May 2, 2012 | 11:00 AM
boosted-fc3s's Avatar
boosted-fc3s
Pull the motor. Its easily accessible in the passenger footwell. Its 3 screws. Once its turn the blower motor off, turn the key to on, and see if the fan cage spins. Usually when the resister is shot it'll work on a few speeds and not others. Never seen it never shut off though.
