no ac at idol 2003 hemi ram
Old Jun 11, 2012 | 08:45 PM
  #21
headbutt1138's Avatar
headbutt1138
got my fan from napa. and i had to cut plastic around a/c line of new fan to install. not a big deal. tin snips did it no prob
Old Jun 18, 2012 | 01:39 PM
  #22
ScooterCat's Avatar
ScooterCat
Originally Posted by ScooterCat
Thanks. I'll be replacing the fan motor with the 4Seasons 35077 as soon as my new one arrives.
OK, got the motor replaced and...
seems like the fan is turning backwards. Air is blowing from inside the engine compartment out the front.
Anyone else have this problem?
Old Jun 20, 2012 | 05:26 PM
  #23
broncoremy's Avatar
broncoremy
Is it possible that you have the polarity of the power plug reversed?
Old Jun 21, 2012 | 06:49 AM
  #24
ScooterCat's Avatar
ScooterCat
Don't see how I could have. The connector only fits one way.
Old Jun 21, 2012 | 10:20 AM
  #25
kenneymc's Avatar
kenneymc
Sounds like fan is wired backwards internally from what you need. What's it have, positive and ground wire? Try running wires from battery to it, but reverse the positive and ground from way they are in factory plug just to see if it will now turn in the proper direction.
Old Jun 21, 2012 | 02:27 PM
  #26
ScooterCat's Avatar
ScooterCat
Yep, just power and ground. Already planned to try reversing the connections when I get a chance this weekend.
Old Jun 22, 2012 | 10:12 AM
  #27
broncoremy's Avatar
broncoremy
Having just done it, I agree. The wire assembly has not been modified going back to the fusebox, has it?
You can pop the relay out at the fusebox and check to see that 12 VDC & GND are coming out at the proper pin on the connector.
Old Jun 22, 2012 | 11:25 AM
  #28
ScooterCat's Avatar
ScooterCat
... The wire assembly has not been modified going back to the fusebox, has it?
Nope, no mods.
Old Jun 22, 2012 | 12:59 PM
  #29
weedahoe's Avatar
weedahoe
Hall of Fame Member
If it is blowing instead or pulling air through then the wiring is backwards. Just because YOU have it wired right doesnt mean internally the fan is wired correctly.
Old Jul 9, 2012 | 09:47 AM
  #30
ScooterCat's Avatar
ScooterCat
Well, finally got around to fixing this. Swapped the (+) and (-) connections and all is well.
