E-Fan install on my 2003 Ram 1500
on
Good Job!!!
I did mine very similar except used the probe that came with the Flex-a-Lite kit. Might swap it out some day. The flex fan pulls 3300 rpm and pulls only 18 amps and with a 180* thermostat I NEVER see the temp needle go much past about 10 o'clock on the temp gauge even when pulling about 7000 lbs...
Cooling Fan sensor preset too low
The sensor is preset at 185 on, 170 off. I was worried that it wouldn't "match" the stock thermostat being 190 I believe, but once the temps climb up to just below half way, it pretty much stays right there, just like it did with the clutch fan. Even in traffic, never went to half way on the temp gauge. Seems to work out well so far.
I guess maybe that the fan might run more continuously since the temps will always hover around 190-200 .... so that might be a little something to think about.
You are correct that fan will run continuosly, as engine coolant will stay above 185 degrees if your stock t-stat is 195 degree..you need sensor that has fan engage at 210-215 (like the fan clutch did) and then go off at approx. 195 for best fuel economy and less strain on electrical system.
.When your driving (not towing) fan should not come at all,,this will also give you mpg increase..Since A/C has its own fan,,, your engine cooling system temps will flucuate much less often. this will give you more mpg's, since less engine heat results in longer engine life,,,the exception to this is also to keep your foot out of throttle now that you've added about 12-15 more hp from no fan blades turning..
.The other engine "must-do" is Gibson shorty headers. easy install.. these will keep engine running cooler and increase hp by scavaging exhaust faster. no need to replace complete exhaust on hemi engine "unless" you like loud noises.. I live in Phoenix,az..nuff said..cya
