noisy power steering
Old Aug 19, 2005 | 05:17 PM
1SlowFormula's Avatar
1SlowFormula
Default noisy power steering
Is it normal to have a noisy power steering system in these things? It almost sounds like pump whine but a little less of a squeel that you normally get when a pump is low on fluid...
I checked the fluid and everything looks good there, now I am just wondering if this is normal, but I don't think so because it is loud as hell... My fiance can hear when I am parking when she is in the house with the doors and windows closed. It started showing up every once in a while at about 400 miles, the truck now has 850 miles and does it almost constantly when the wheel is turned in either direction...
I am already having issues with the dealership I bought the truck at, and don't know if I should add it to the stuff the need to fix or let them fix their stuff, and tak the truck to another dealership for all other repairs...
BTW, read the link in my sig if you don't already know what my problems with the dealership are.
Old Aug 19, 2005 | 05:47 PM
osteodoc08's Avatar
osteodoc08
Default RE: noisy power steering
Let them look at it. Most PS pumps will make some noise at full lock.
Old Aug 19, 2005 | 06:45 PM
1SlowFormula
I knowwhat you are saying about full lock, but this makes that noise (about what you expect at full lock) whenever the wheel is turned even if it is turned slightly past 80* or so. Meaning if you drew a line at the top of the wheel and turned the wheel to the left or right past ~ 80* or 2:30/9:30 on a clock, it makes that same sound that most make when they are at full lock. I was just wondering if this is normal due to the fact that it is a truck.
Old Aug 20, 2005 | 12:18 AM
osteodoc08's Avatar
osteodoc08
Doesn't sound normal. Mine doesn't do it, so you might want to get it checked out.
Old Aug 20, 2005 | 03:23 AM
Red Ram Hemi 2005's Avatar
Red Ram Hemi 2005
I dont beleave I have ever heard any noise out of mine.
Old Oct 29, 2005 | 11:11 AM
jjintxs's Avatar
jjintxs
Did you get this resolved? I have a 04 Ram 2500 Cummins (40k miles on it), and am having the same problem. I get the noise after first starting it up, up until about 15 minutes after it has been started. Then it stops. Fluid level is full, belt is good. I get the noise at idle, slow engine speeds when initiating a turn (both left and right) from 12 o'clock to 9 o'clock and to 3 o'clock positions.
Old Nov 1, 2005 | 11:39 AM
1SlowFormula
ORIGINAL: jjintxs
Yeah, sorry I didn't update the thread... I took it to the dealer to get a few other things resolved and they looked at it and said that they had to blead some air out of the system. It was dead quiet for a few weeks, and has started to get a little bit of the noise back but nothing like before.
Old Nov 1, 2005 | 03:40 PM
osteodoc08's Avatar
osteodoc08
Hmm, where's the bleed srew? J/K. When I do the steering pump flush I just move the wheels lock to lock a few times and it is supposed to bleed the system. I wonder how they did yours?
Old Nov 1, 2005 | 03:46 PM
lucifuhrman's Avatar
lucifuhrman
Glad you posted on this. My truck is new - about 5 weeks old (1700 miles), and I've been noticing what I think is excessive noise coming from the power steering at angles well short of full lock. May take the truck in and have the dealer take a look.
Old Dec 4, 2005 | 02:32 PM
capetronics's Avatar
capetronics
My truck has 800 miles on the clock and it just started doing it. Its not loud but I can feel it and hear it and it bugs me. It sounds like a high frequency hum. Man, when I went to check the fluid level there was a sharp popping sound when I took the cap off. That humming sound makes me believe that not enough oil got to certain moving parts. I am around hydraulics all day and if a machine started making a noise like that it needs to be repaired/replaced- No two ways about it. Lets see what the dealership says on Monday.
__________________________________________________ _______
2006 RAM 1500 SPORT - Quad- 20's -HEMI Powered.
