Special tool to change shocks?
Old Jul 14, 2012 | 12:28 PM
MikeHTally's Avatar
MikeHTally
Then you only need basic tools. Put it up on ramps (leave the suspension loaded), take the top loose first, then remove the bolts holding the bottom. Pull the old shock down and out. Put the new shock in using the reverse procedure.
Old Jul 16, 2012 | 09:54 AM
MeAndMyHemi's Avatar
MeAndMyHemi
The "Special Tool" was a 19/32 socket on a 1/4" drive breaker bar to hold the shock shaft while loosening the top bolt with an 18 mm box end wrench. Saved $ 200 bucks on labor (Ripoff) and it took me less than two hours.
Booyah!
Old Jul 16, 2012 | 10:50 AM
ewing111's Avatar
ewing111
Booyah!
nicely done. good work on not just blindly following dumb shiz and getting ripped off. $$ for more mods, woo hoo!
