Etc problems!
Old Aug 29, 2012 | 03:55 PM
willdikem66's Avatar
willdikem66
Sounds like an electrical issue.
As for the p300 have you changed your plugs. If so Did you keep the OEM champion coppers
Old Aug 30, 2012 | 06:43 AM
Northern Goat's Avatar
Northern Goat
Originally Posted by Dmac25
I'm think it's probably the MAF throwing at least 2 of these. Im not real sure though.
Hey Dmac hate to be a bummer, but there is no MAF sensor on a 2004 Hemi. Check ground straps as your getting a lot of different codes all at once that don't really have a lot to do with each other.
Old Aug 31, 2012 | 07:08 PM
Dmac25's Avatar
Dmac25
Yeah I did some research and saw that! No I havnt changed the plugs. I just recently purchased the truck. It had been sitting for a while and after I drove it for a while these codes popped up. I'm new to the hemi ram so bear with me lol I guess I need to change the plugs (which sucks considering there's 16..) I'll check them but are there any sensors that may possibly need cleaning/replacement?
Old Aug 31, 2012 | 07:43 PM
Dead2Fall's Avatar
Dead2Fall
P0127 is intake air temp too high. That coupled with the barometer one means somethings wrong on the air intake side and probably sensor related. If it's sensing weird stuff with air intake and trying to compensate, I could see a possible random misfire.
Old Aug 31, 2012 | 07:47 PM
Dead2Fall's Avatar
Dead2Fall
Since your getting a code from map sensor and iat sensor, goat is probably right with it being something electrical.
Old Sep 1, 2012 | 10:09 AM
willdikem66
Map Sensors are cheap on Rock Auto if you just wanted to try one. 15 bucks.
Old Sep 1, 2012 | 10:15 AM
Dead2Fall's Avatar
Dead2Fall
You could replace both for under $30
Old Sep 1, 2012 | 10:29 AM
willdikem66
I never would have gone to rock auto if it wasnt for this forum, Im glad i did ive prolly saved more than ive spent!
Old Sep 1, 2012 | 10:56 AM
Dead2Fall's Avatar
Dead2Fall
Sometimes they aren't the cheapest
Old Sep 1, 2012 | 11:58 AM
willdikem66
Dang ive yet to find a part that i needed that they werent cheaper on, im sure there are some though
