Etc problems!
Old Aug 27, 2012 | 10:56 AM
Dmac25's Avatar
Dmac25
Default Etc problems!
I have a 2004 dodge ram 1500 hemi and the etc is giving me fits. Im new to the site, as well as the truck, and couldn't find what I was looking for hence my post lol. Every time I turn the truck on the etc (electronic throttle control) and cel lights are on. I cleaned the throttle body (correctly) and reset PCM via battery. The truck doesn't really seem to have a loss of power. However throttle response isn't that great and it won't shift into overdrive! That's my main concern. I would think limp mode just limited it to one gear. Anyways if anyone can help me out I'd appreciate it.
Old Aug 27, 2012 | 01:40 PM
willdikem66's Avatar
willdikem66
Reground your throttle body. You would be superised at the difference.
Old Aug 27, 2012 | 04:38 PM
Dead2Fall's Avatar
Dead2Fall
Bad tps maybe?
Old Aug 27, 2012 | 05:30 PM
Dmac25's Avatar
Dmac25
Yeah I'm hoping it's a sensor or even better just a wire. For some reason my obdII port isn't working? Not getting power so I can't read the codes. I'll get the mechanic to mess with it in the morning and see of he can figure it out I guess. Any other ideas at this point?
Old Aug 27, 2012 | 06:24 PM
MoparPaul's Avatar
MoparPaul
You can try re-calibrating the TPS
With the key on (engine not running) Slowly depress the pedal to the floor in an span of 30 secs, then release slowly over 30 secs... Its worth a shot anyways...
Old Aug 27, 2012 | 11:42 PM
sabin420's Avatar
sabin420
In the manual it just says remove the battery terminal for 2 minutes, then reconnect the battery. Turn the key to the on position but do not start the car. Wait 10 seconds till the lightning bold symbol turns off. That should re-calibrate the throttle body. But I do suggest if you got an aftermarket intake, or just installed one, take it back off and wipe out the inside of all the tubes. I had a problem with some minute debris on the inside of my brand new CAI that made my ETB go haywire until I wiped it out.
Old Aug 28, 2012 | 12:00 PM
willdikem66
Key trick will tell you if the OBDII port dosent work....
Old Aug 28, 2012 | 04:33 PM
Dmac25's Avatar
Dmac25
Well considering there's no power to the obdII as well as the built in code reader not working, I'm assuming the truck has some electrical problems or damage. Maybe rodent or water? It's not responding to anything I do. The crazy thing is it still drives and shifts into every gear but overdrive.
Old Aug 29, 2012 | 12:29 PM
Northern Goat's Avatar
Northern Goat
That is a myth and it applies to the diesel Rams not the Hemi's. Here is the one for hemi's, right out of manual.
1. Remove negative battery cable 30-60 seconds
2. Recconect cable.
3. Turn key to on postion (But do not start)
4. Wait 30 seconds for PCM to learn electrical parameters
5. Turn key to off postion then carry as normal.
I confimred this with head mechanic at local stealer.
Old Aug 29, 2012 | 03:37 PM
Dmac25's Avatar
Dmac25
Finally got my codes read. So here they are
P0300 (random misfire)
P2305 (eradic ignition signal?..)
P0129 (barometric pressure out of range)
P0127 (low coolant temp)
I'm think it's probably the MAF throwing at least 2 of these. Im not real sure though. Just give some feedback and if you have any pointers o these codes I'd love to nip this in the bud.
