Anti-Seize and Grease?
Old Aug 28, 2012 | 11:51 AM
1ATony's Avatar
1ATony
Former Vendor
I've used anti-seize on plugs for years. It will defiantly help during your next tune-up. I also use it on lug nut threads, and the brake caliper bolts. Even with a little anti-seize those caliper bolts can be tough to break free.
Old Feb 3, 2013 | 10:35 PM
timekop's Avatar
timekop
Do a favor for the next guy who gets your truck. It helps so much to grease the threads on plugs, bolts, etc. Quick thing to do to make your job easier later.
Old Feb 4, 2013 | 07:58 AM
dirtydog's Avatar
dirtydog
Moderate User
I don't use anything on plug threads. Not being able to get the plugs off means you either torqued them down too much, your engine isn't cold, or you went way over your 30kmi service.
30kmi service plugs don't need anti-seize. 100kimi do and should be used extremely sparingly. Using a cutip is sparingly. Using your finger making a mess is just that..making a mess.
ALL plug boots need dielectric grease. While some may not think it doesn't do anything, they have no idea how electronics work. The smallest amount of corrosion can hinder performance. You need a clean connection for best reliability and performance.
As far as anti-seize causing problems, yeah, if you get that stuff on the electrode it'll cause problems.
**Warning to all anti-seize users. DO NOT over tighten your plugs. anti-sieze is a lube that can allow you to overtigthen!!!
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
Anyone who uses anti-sieze on spark plug threads should do as follows:
apply sparingly to first few threads only. Once applied, wipe the threads off with a clean rag. there will be plenty there for benefit and nowhere near enough to allow overtighten or plug/performance complications.
a small dab on just on area of threads is usually enough. While threading it in, the lube will spread evenly on it's own.
***In the link above, they are using WAAAAAAY too much anti-seize. Holy crap!
Old Feb 4, 2013 | 09:21 AM
rought's Avatar
rought
I wish anti sieze worked on the exhause bolts,,,, because exhause bolts seem to be the biggest problem removing and they just get worse in time.
