2005 Hemi transmission problems
Old Sep 1, 2012 | 10:38 PM
HEMI_NOOB's Avatar
HEMI_NOOB
Default 2005 Hemi transmission problems
On cold starts, after starting the motor, if I put it in gear right away, it would not drive. If I put it back in park for a few seconds and tried again, you could feel the transmission engage and shift into gear.
On cold starts, if I let it idle for about 30-45 seconds, it'd shift into gear properly.
Took it to a transmission shop, was told the transmission had over heated and had severe damage.
Had tranny rebuilt to "2012" specs, spent $3300. Picked it up this morning, they just got back from a test drive. Drove it to work.
It sat in the lot all day and when I went to leave tonight....started it, put it in gear, and the transmission did not engage.....just as before.
Let it idle for about 30 seconds and it shifted normally.
Is that a normal trait for the 05 Hemi 5.7's?
Old Sep 1, 2012 | 10:43 PM
Dead2Fall's Avatar
Dead2Fall
No it's not. You dont hear anything underneath on that first shift?
Old Sep 2, 2012 | 07:58 AM
Gone Fishin's Avatar
Gone Fishin
There's a check valve in the tranny thats allowing the torque converter to drain, its not an uncommon problem. When you start the truck up, wait for a short time before you put it in gear, it will engage OK. Seems the tranny shop may have missed a few things.
Old Sep 2, 2012 | 08:32 AM
hemi4109's Avatar
hemi4109
Similar problem on this link that might help.
https://dodgeforum.com/forum/3rd-gen...nto-drive.html
Old Sep 2, 2012 | 09:33 AM
Toefur's Avatar
Toefur
there is a TSB on this:
http://dodgeram.info/tsb/2005/21-015-05.htm
Old Sep 4, 2012 | 02:45 PM
DodgeCares's Avatar
DodgeCares
Noob,
Just an FYI with regards to the TSB mentioned above, the labor time shown for the repair is under 2 hours.
Old Sep 5, 2012 | 12:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you had it rebuilt and picked it up this morning only to have it do the same thing, I wouldnt be here, I would be on the phone with the shop. They would be coming to pick it up and be pulling it back apart.
$3300 and the same issues happening..........shiiittttttttt.......not me
Old Jun 4, 2018 | 12:09 AM
Markus18's Avatar
Markus18
Default Transmission or something else?
Wrong place - post moved to the different area.
Last edited by Markus18; Jun 4, 2018 at 07:00 AM. Reason: Wrong place - post moved to the different area.
