Intermittent wiper DIY fix
Old Feb 9, 2017 | 01:49 PM
  #51
VOConnor's Avatar
VOConnor
Thanks, repair took 1/2hr and wipers are working correctly now.
FYI, if you've ever had your windshield replaced you most likely won't need to worry about the little clips for the wipers. The glass shop will have lost them for you.
Old Feb 10, 2017 | 06:35 AM
  #52
ewing111's Avatar
ewing111
Lol...thanks for that, I needed a laugh this morning... Glad it worked for ya...
Old Feb 27, 2019 | 11:36 AM
  #53
Tad Wicks's Avatar
Tad Wicks
Hi, I have an "02" 1500 that only high speed works on the wipers and when I shut them off the blades stop where they are and don't return home.
Old Jul 16, 2019 | 01:01 AM
  #54
DDEC's Avatar
DDEC
Thumbs up Thank you!
Thanks for taking the time to do this. I found it so helpful.
Old Nov 25, 2019 | 09:25 AM
  #55
Hossie's Avatar
Hossie
Worked for me, thanks a bunch!
Old Nov 16, 2020 | 04:17 PM
  #56
chugalong's Avatar
chugalong
This was a great help! Issue resolved! Easy fix!!!
Old Dec 29, 2020 | 10:37 AM
  #57
Benji Pickard's Avatar
Benji Pickard
Default Wipers staying in up position
I did this as described and all worked well, didn’t look to bad inside the contact area.
When I assembled everything thing back together my wipers home position is at the top of the wipers travel now instead of the bottom of the window. Any ideas? I am pretty sure I put the rounds disk with the two spring contacts back in the same orientation...
Old Dec 30, 2020 | 08:20 AM
  #58
ewing111's Avatar
ewing111
Maybe your motor got installed in reverse? I’m really not sure, sorry. It’s been a long time since I did this. I was re reading the original post and that’s my best guess.
Old Feb 13, 2021 | 09:36 AM
  #59
christorrn's Avatar
christorrn
Great post thanks, just what I was looking for.👍
Old Sep 10, 2023 | 08:44 PM
  #60
gcburkett's Avatar
gcburkett
Finally decided to try this on my old 2005 truck and the intermitten function is working again. Big thanks to those who posted this original fix without replacing the motor.
