Fram XTended guard 10,000 mile protection filters.
My son bought me a set of fram filters when on holiday in the states for my 03 Hemi.
One was for the engine oil.
The exact model is "Fram XTended guard 10,000 mile protection filter XG16 for synthetic oil".
I live here in the UK and filters can be expensive.
Question is, I've read several stories where people have said Fram filters suck big time!
I don't want to waste this filter by chucking it but, are these ok to use?
Particularly this model filter.
Al.
Al.
It's a nice filter with Synthetic media and metal end caps, BUT, it does have a plastic bypass valve and a very thin metal body(outer canister part) which you can probably squeeze with your hands and feel. I guess the thin metal part isn't of concern if the filter is tucked way up out of any sticks/brush being able to damage or poke any holes in it.
If your using it for standard oil changes, it's descent. I wouldn't use it for extended intervals as stated in their claims. The pleats are very thick and can cause reduction in flow which is the case with ANY oil filter I suppose when going extended intervals due to obvious blockage from too much particulates in dirty oil.
I think it's filtration is excellent and the anti-drainback part is as well even though it's plastic. It could have a few more seals inside there for contamination purposes, but I think it's still better than a cheap paper capped filter.
I've always used Fram. The first time I didn't use Fram (because it was a special, filter and oil), I got an engine knock within 5 miles of changing the oil. That time I used a Bosch filter. I will never use a Bosch filter again. I ended up having to change the motor. I've used K&N, Purolator, and Napa filters on other vehicles without a problem too.
Trending Topics
Fram got a bad rep for the drain back valve.. it would stick, and ruh roh raggy...
They've tried to beat that rap for a while now.. they went as far as to serve mother mopar with papers when the TSB for diesels went out (telling folks not to use Fram, round about '01 or so)..
The problem has been addressed, but the damage done in my opinion.. filters are relatively cheap, and good dang insurance.. I won't use anything but champion labs products.. I floggin love the royal purple gizmo, but even with it you'll never find me running more than 5k on one..
Oil changes are simple, and worth a lot more than just the change itself.. it gives you an opportunity to crawl around under and around the truck, which let's you discover other issues fairly early.. you can see the condition of the oil, and if you care to open a filter you can see even more.. grease points, ujoint pulls, ball joints, shocks, brakes, rack leaks, CV joint boots, air in tires, yada yada blah.. all a simple check every 5k miles while your oil drains, that can save you a fortune... And for the cost of oil and filters.. just my opinion, though..
