I'm stumped!
Old Oct 12, 2012 | 07:55 PM
SC_Ram's Avatar
SC_Ram
Talking I'm stumped!
OK fellas....here I come yet again scratching my head.I got a '05 Sporty 5.7 Hemi throwing a 0300 code.I switched out the plugs and wires.I don't think I have a burnt valve since I can feel no vaccum from either exhaust tip.Where to go/what to do now.I'm thinking it may be an O2 sensor but which one? I don't want to just guess and waste time and money.Any help or ideas as always are appreciated.
Old Oct 12, 2012 | 10:44 PM
willdikem66's Avatar
willdikem66
Are you using any excessive coolant?
O2 sensor could be it but that usually throws a specfic code for the O2.
Old Oct 13, 2012 | 08:37 AM
SC_Ram's Avatar
SC_Ram
No excessive coolant here.I just looked at the overflow tank yesterday and both the rad and the tank are where they should be.
Old Oct 13, 2012 | 08:59 AM
Gone Fishin's Avatar
Gone Fishin
My first thought was possibly a crank sensor, but it would throw a different code by itself.
Possible (?) water in the fuel???
When you did the plugs, did you get the plug wire overlay back in oem location----can cause problems like you're describing.
Old Oct 14, 2012 | 07:04 AM
SC_Ram's Avatar
SC_Ram
I'm assuming an overlay is where the wires run under the air intake on the top end of the engine.When I did the wires,I did them one at a time to make sure they all got the right routing and went exactly where they were suppose to.That way they wouldn't be sitting on top of something they weren't suppose to be and/or possibly arcing out either.My biggest problem with this whole thing is that the truck might not do this for another 2 months and then again it might happen tomorrow.Yesterday I took off the air intake and cleaned out my throttle body real good.It wasn't too awful.I've seen worse but I did it basically just to eliminate that as a possibility.I very well may have a bad computer too.I bought this truck from a dealership with 35K on it a few years ago so I don't know its history.I've also thought that maybe someone before me had the computer flashed and maybe the dealer reset it too OEM and that might be having an effect on it.I think if the 'puter was bad I would have a whole host of other problems too though.
Old Oct 14, 2012 | 03:49 PM
Gone Fishin
Have you checked the connection condition for the computers, at least the ones under the hood?
If you go to Weedahoe's sig, you can download the FSM. This will give you the diagnostic procedures for testing the various components like the O2 sensors.
Old Oct 15, 2012 | 06:20 PM
SC_Ram's Avatar
SC_Ram
Thats a good idea.It never crossed my mind.The most irritating part outside of the fact that it's such a wide range of things that cause the random misfire is my truck might not misfire again for another couple months or more.It occurs very infrequently.When it does,I can stomp the gas and it just quits.(vaccum leak possibly?) Normally you can't even feel the thing runnin' while your in it though.
Old Oct 15, 2012 | 08:38 PM
Gone Fishin
You might try putting some dry gas in the tank, (the red bottle only). If there is water laying in the bottom of the tank, you may be picking it up randomly.
Most vacuum leaks aren't random.
Old Oct 16, 2012 | 11:18 AM
willdikem66
Agreed about the leak, and if you go through most of the Misfire threads you will see that 90% of people say when they stomp on it that you wouldnt even guess that it had a Misfire, i personally found out the same
Old Oct 16, 2012 | 06:35 PM
SC_Ram's Avatar
SC_Ram
So did you ever figure it out (what was giving you the misfire)?
