Please help!!!! Driving me nuts
Old Oct 23, 2012 | 09:20 AM
Wilson01960196's Avatar
Wilson01960196
Originally Posted by Izero
I would say that it sounds like a ground issue.
If you search on here there is a thread somewhere about where the grounds are at... but worse comes to worse look for black wires from the negative battery lead, and starter... those are the big grounds....
It also sounds like you have a major clockspring problem, so I'd prolly replace that too.
Can i change the clockspring myself? Or does the dealer have to do it.
Old Oct 23, 2012 | 09:51 AM
Izero's Avatar
Izero
Well it's really your call there, I'm sure you "can" do it yourself, but I personally do not mess around when it comes to removing and reinstalling my airbag, which is why I'd just pay to have the dealer do it.
Old Oct 23, 2012 | 10:08 AM
Wilson01960196
Yeah good point idt i wanna tackle that job..im more worried bout the speedo than the cruise tho
Old Oct 23, 2012 | 10:19 AM
Izero's Avatar
Izero
Well the Speedo issue might not be related to the clock spring but it is possible I suppose, if they share a ground or power source.
I would attempt swapping with a known working cluster before taking it in for the clock-spring.
Old Oct 23, 2012 | 11:09 AM
DodgeCares's Avatar
DodgeCares
Originally Posted by Wilson01960196
I dont think it could be my circuit board in my cluster bc i bought a brand new cluster from dodge and had it programmed for my vin and mileage..so the circuit board in it is brand new..maybe im wrong
Wilson,
If you bought a brand new cluster from the dealer did they install it and program it there as well? If so I would take it back. If it is under 12/12 it should be under warranty. Did you get the cluster to solve the original speedo issue? I agree with the possible ground issue, but you may want to have the dealer take another look, especially regarding a clock spring if thats the direction you are going to go.
Old Oct 23, 2012 | 03:45 PM
Wilson01960196
Originally Posted by DodgeCares
Wilson,
I had them order the cluster and they got my bin and mileage and said it would be programmed when it camr from the manufacturer..i put it and and it never fixed anything..as soon as i put it in my abs and brake light came on nd it was never on before so i showed it to them and they said there is a problem somewhere else that it cant be the brand.new cluster..and i gave them my old one so i didnt pay the $550 core charge..im more worried bout the speedo than the cruise bc its not tracking my miles right
Old Oct 23, 2012 | 04:07 PM
Wilson01960196
Wilson,
I jus looked and noticed my ground that goes on my battert terminal is really crusty and white on tge end
Old Oct 23, 2012 | 04:10 PM
Wilson01960196
Wilson,
I jus looked and noticed my ground that goes on my battert terminal is really crusty and white on tge end could that effect the ground ur talking bout..there are other grounds that go to the framr by the front wheel and another looks like it goes the the botom of the engine behine the power steerong resevior...on wire was laying against the case and it had a little crack in it so i wrapped it in electrical tape..the wire was hot ehere it was touching from where i had jus driven it
Old Oct 23, 2012 | 04:25 PM
Izero's Avatar
Izero
Clean it!
Use Water and Baking Soda, and that stuff will come right off
Old Oct 23, 2012 | 04:30 PM
Wilson01960196
Ok..could that stop the current enough when its hot out to mess with the speedometer? In tye morning when its cool outaide and the truck hasbt been running it fine
