Please help!!!! Driving me nuts
Old Oct 21, 2012 | 09:19 PM
Wilson01960196's Avatar
Wilson01960196
Default Please help!!!! Driving me nuts
Heyy..i am nee to the forum and hope i am doing this right..i have a 2006 ram 1500 4x4 5.7l hemi..ever since i bought the truck my speedometer seems to "lag" at times..ill be accelerating and itll randomly freeze for a brief moment than keep going..when it does freeze my turn signals freeze on the cluster to..lights on the outside continue to work fine but it freezes on the cluster..wgen it is colder out like below 45 it works perfectly! I have replaced the input and output sensor..driver side hub..sensor in the rear diff..and put a brand new cluster in..still no fix.
Old Oct 22, 2012 | 12:30 AM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move the post to the 3rd Gen Ram section.
Old Oct 22, 2012 | 09:19 AM
Izero's Avatar
Izero
Sounds like a bad electrical circuit somewhere behind the cluster, or possibly a bad main ground.
So check your grounds first, then pull the cluster and see if the harness is burnt/melted or if there are any damaged wires behind it.
You can also check the cluster itself for damage as well.
Your other option is to bring it to a reputable dodge dealer and have them take a look.
Old Oct 22, 2012 | 10:11 AM
Wilson01960196
I have had the cluster out several times and all the wires look fine...where will the main ground be? Ill check it
Old Oct 22, 2012 | 10:14 AM
Wilson01960196
Also my cruise only works at certain speeds luke 45-50to or 70-75..and after i had the new cluster put in my abs and brake light came on and it was never on before and they checked the codes and didnt pull anything
Old Oct 22, 2012 | 10:22 AM
Izero's Avatar
Izero
I would say that it sounds like a ground issue.
If you search on here there is a thread somewhere about where the grounds are at... but worse comes to worse look for black wires from the negative battery lead, and starter... those are the big grounds....
It also sounds like you have a major clockspring problem, so I'd prolly replace that too.
Old Oct 22, 2012 | 07:53 PM
Wilson01960196
How do i do that?
Old Oct 22, 2012 | 08:49 PM
kenneymc's Avatar
kenneymc
Never had my cluster out, bad it also sounds like cracked solder joints on the circuit boards. Have a look at them.
Old Oct 23, 2012 | 09:13 AM
Wilson01960196
Where do i look fir the curcuit board?
Old Oct 23, 2012 | 09:18 AM
Wilson01960196
I dont think it could be my circuit board in my cluster bc i bought a brand new cluster from dodge and had it programmed for my vin and mileage..so the circuit board in it is brand new..maybe im wrong
