Ram won't start
I have a 2006 dodge ram 1500 4dr, 4x4, 5.7L hemi. While was driving it the check engine and check gauges lights came on and the truck lost all power. The engine still cranks and fuel pump is working, but won't start. Took it to a dealer and they said it is something internal in the engine and didn't tell me what he codes are. Told me to just replace the motor with a used one. Any suggestions what the problem is?
You need to know the codes. If you paid the dealer to diagnose the problem then he needs to tell you the codes also. I don't think your dealer is being honest with you. I had similar symptoms and turned out to me my camshaft position sensor. A $25 part that you can easily replace yourself.
You can download the FSM from Weedahoe's sig, and look up all the DTC codes and diagnostics for free from the FSM.
From reading your post, and if it happened as you said, it sounds more like a electrical or computer issue. An internal mechanical failure doesn't usually lead to a systems power outage, especially if the engine cranks over but no start. Check the basics first, spark, fuel, air.
xiskids,
Difficult to say without the full diagnosis details. I would recommend asking to speak directly to the Service Manager. He should be able to advise what the repair will have to be and why.
Trending Topics
To the OP you cant just check sensors you have to have a clue or a code pointing you to the sensor. Get the codes they told you that you had and let us know what they are.
Definitions:
C0301 - Failed Suction Fan (Cannot find any additional information on this yet.)
C0154 - (Cannot Find anything on this code ANYWHERE)
P0001 - Fuel Volume Regulator Control Circuit/Open (Electrical Short in-line with the Fuel Pump and/or Fuel Regulation System)
I am having trouble believing that the C-Codes are genuine DTCs.... mainly because I can't find any record of them AT ALL.
To get a true list of C-Codes, you need to do the following:
1) Insert Key
2) Press and Hold the Trip Button (with ignition off)
3) While Holding Trip Button Turn Key to ON but do not start vehicle.
4) Watch the Show and Write all Codes down.
Considering you said all your gauges when nuts it has to be a C-Code or multiple C-Codes, so doing that procedure will help us narrow it down.
All of your issues point to something crazy going on with your electrical system.
Lets start with pulling the real C-Codes, and then we can go from there.
1) Insert Key
