06 Laramie
Thanks for all your responses - as expected the dealer called me today willing to go lower on the price.
When I was talking with him on the phone he told me the one previous owner had a remote start added to the truck, but removed it prior to trading it in.
They said it was replaced with "quick disconnects" and no wires were spliced into. But should this be a red flag??
well it will make installing a R/S yourself a lot easier, but as long as it looks like a quality removal I wouldn't be too concerned about it... just make sure it doesn't have any other starting or electrical issues during your test drive and you're set.
That is a freakin awesome truck man! You'll definitely love it!
Thanks DodgeCares for the build sheet!
Does anything in the below stand out as rare / something to keep an eye out on?
DH3P- Elec Shift-on-the-Fly Transfer Case
VL Leather Trim 40/20/40 Bench Seat -D5 Med Slate Gray
AHC Trailer Tow Group
AHD Heavy Duty Snow Plow Prep Group
APAS Monotone Paint
A76P 5.9L TD Eng(ETH)/4Spd A/T 48RE (DG8)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CG1S Next Gen Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CMAP Heated Front Seats CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CVHP Front Center Seat Cushion Storage
CVNP Folding Flat Load Floor Storage
CV2P O/Head Console w/Trip Computer/UGDO
DGBS All 4-Speed Automatic Transmissions DG8 4-Spd. Automatic 48RE Transmission
DHAP Lock-Up Torque Converter
DH3P Elec Shift-on-the-Fly Transfer Case
DJQS 5,200# Front Axle DMF 4.10 Rear Axle Ratio
DRQP 11.50 Rear Axle DSA Anti-Spin Differential Rear Axle ETH 5.9L I6 HO Cummins TD Engine GACS Tinted Glass Windows
GFEP Rear Power Sliding Window
GNCS Sun Visors w/Illum Vanity Mirrors
GNKS Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror GPG Power Black Trailer Tow Mirrors GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HADS Air Cond'ing w/Dual Zone Temp Cntrl
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach JBBS Instrument Panel Woodgrain Bezel JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JTDP Power 6-Way Driver/Passenger Seats
LBCS Glove Box Lamp LBDS Ash Tray Lamp
LCLS Front Dome w/On/Off Switch Lamp
LDAS Underhood Lamp
LMAS Halogen Headlamps
LNJS Fog Lamps LPES Cargo Lamp
LSAS Security Alarm MBFS Bright Rear Bumper
MB3S Body Color/Bright Front Fascia
MDAS Front License Plate Bracket
MF1S Bright/Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MJBS Chrome Bodyside Molding
MTES Laramie Badge MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
NAE California Emissions
NFUS 34 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler NHK Engine Block Heater
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCS Heavy Duty Engine Cooling
NZCP Current Generation Eng Controller
PDMA Mineral Gray Met. Clear Coat
QDMS Mineral Gray Met. Clear Coat
RAAC All Radio Equipped Vehicles RAK AM/FM Cass/CD 6-Disc MP3 Radio
RCKP Infinity Speakers RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls RSAS Sirius Satellite Radio
SBES Power Steering
SCVS Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch TT5 LT265/70R17E OWL On/Off Rd Tires
TZGP BF Goodrich Brand Tires WF1S 17" Steel Spare Wheel
WGXP 17" Aluminum Chrome Clad Wheels
WLZC All Aluminum Wheels
WMJP Center Hub
XAPS Power Adjustable Pedals
XBSS Pickup Box XEA Tow Hooks
XEFP Transfer Case Skid Plate Shield
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XSCS Bright Interior Accents X95P Call SIRIUS to Activate@888-539-7474 X97P 1-Year Service Provided by SIRIUS
YAAS Build To U.S. Mkt. Specifications YCF California Emissions States Order
YG4A 5.5 Additional Gallons of Diesel
ZEHP Spring - Left Front ZGRP Spring - Left Rear ZTHP Spring - Right Front
ZVRP Spring - Right Rear Z7CP GVW Rating - 9000# 0AZA 55610-709 Mga
0Az (Out End of 95)
1AAS U.S. Dealer Retail 132S Zone 32-New York
2THA Customer Preferred Package 2TH
2UH Customer Preferred Package 2UH
APAS Monotone Paint
JJAS Cigar Lighter
JPBS Power Locks
LDAS Underhood Lamp
MXBS Front Air Dam
NHMS Speed Control
SBES Power Steering
WMJP Center Hub
0Az (Out End of 95)
