Tailgate Assist
So have have heard of the EZ Lift Bar by Hopkins and the Shock by Dee Zee.
Is there any other Tailgate Assists out there that might be better??
It would be really nice if someone made a replacement hinge with spring assist built in, like the new trucks.
got a torsion bar type thing on my tail gate and it really works nice. A little kid can put it up. one hole is drilled on the jab of the bed and the other hole is drilled in the center on the bottom of the tail gate and this round bar just hooks in both spots the holes are about !/2 " in diamiter I got it off ebay for about $20.00
Same here, just it's a pain if you need to take off the tail gate.
I was looking at this one. With my back going in and out, the tail gate is feeling really heavy lately.
http://www.amazon.com/Hopkins-EASYLI.../dp/B000CMHVJO
Looks like you'd have to take your tailgate off, screw the torsion rod into the bottom and then screw it into your bed. Means lining things up and drilling holes in your truck and probably just using self tappers...yikes.
This torsion bar comes with a diagram on a piece of cardboard all you do is line it up at the tailgate and drill the two holes and slip the bent to fit ends in place. no screws at all
