04 Dodge Ram.. SMALL catch in steering SOMETIMES.
Old Dec 17, 2012 | 05:46 PM
seasonaleclipse's Avatar
seasonaleclipse
Default 04 Dodge Ram.. SMALL catch in steering SOMETIMES.
So, Iv noticed this issue a couple times. I let my truck sit all day at work and when I go to get i n it and go home when I back up and turn the steerring wheel counter clockwise there is a SLIGHT and small area where there is a catch. After I go down the road its gone though.. Anything I need to worry about? I just had lower ball joints and sway bar links done and the truck rides so good, I just want to know you guys opinion on this if anyone else had any similar issues, its not even really TOO noticible and its just the one time, if I go down the road and get to a stop sign and turn my wheels back and forth it never does it again which is weird.
Old Dec 17, 2012 | 08:55 PM
MikeHTally's Avatar
MikeHTally
Sounds like it's low on fluid.
Old Dec 17, 2012 | 08:58 PM
seasonaleclipse
I checked the fluid and its hard to tell if its on the add line or full. It definitley goes as high as the add line, and the full line is wet but not colored wet. lol So, ill look at it in the morning again, do dodges require special dodge PS Fluid?
Old Dec 17, 2012 | 10:06 PM
seasonaleclipse
OK Checked fluid, its a hair above the add mark but well under the full mark, its a light pink color (or light right, almost clear) and theres a stain around the top of the power steering resevoir like its been leaking ontop, maybe it needs a new cap?
Old Dec 18, 2012 | 06:19 PM
seasonaleclipse
Topped it off today, I now notice that the PS pump does have a SMALL groan when I turn the wheel, it isnt loud or anything though yet. The fluid is clean though. How long can a PS pump last with a slight groan?
Old Dec 18, 2012 | 06:34 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
My dad's had that. Slowly got worse until it was behaving like busted ball joints.
A new rack was in order.
And you can use ATF+4 to top it off. It should have already had it in there.
Old Dec 18, 2012 | 07:37 PM
seasonaleclipse
How long did that hold up for him? I might drive 100 miles in a weeks time so I am not going cross country. I tend to freak out when I hear a noise and replace things that still have quite a bit of life in it. lol
Old Dec 18, 2012 | 08:06 PM
dodge dude94
'bout 500 mi. Maybe longer. But those were kinda rough, heavily rutted sand road he was traveling a lot put the nail in it's coffin.
Just whatever you do, DO NOT but a reman rack. NEVER.
My dad had his reman go out within 6 months, then when they replaced it with another reman IT blew up on the test drive.
They put a new MOPAR rack on it and ate the entire cost (almost a week in the shop, my dad was pissed).
Old Dec 18, 2012 | 08:23 PM
seasonaleclipse
Jeeze.. I think it might just be the steering pump though. The mechanic last week put lower Ball Joints on and told me everything checked out when he test drove it, that and there is no play in the steering.. Just a little groan and that little lasp in power steering (for a split second when im turning the wheel when im leaving work) when the trucks been sitting at work all day. I panic too much most the time with these things, in youtube videos the sound is a lot worse then this, if it continues to get worse ill have it looked at but hopefully its just in my head. lol
Old Dec 19, 2012 | 07:42 AM
boopadoopa's Avatar
boopadoopa
My last truck A Dakota did the same thing and dealer ship said , the steering intermediate shaft was bent?? They said the universals at the end of the shaft must have froze up and when I turned it caused the shaft to bend.. over time the universal kept failing till I had not much power steering. Check that out a new shaft fixed the issue
