Where to put resistor(s)?
Old 01-06-2013, 11:42 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
maybe you could try opening the glove box while the truck is off and see if the map lights work.
Old 01-07-2013, 07:04 AM
GRNDPNDR's Avatar
GRNDPNDR
GRNDPNDR is offline
Originally Posted by 66three83
No offense, and certainly of no help, but I would hate to be the next owner of your truck!!
Why because I added some lights?? it's neatly done work
But honestly, I'm fairly sure I'm the last owner this truck will see.
that....is a good idea, I'm going to try that when I leave this morning.
Old 01-07-2013, 09:50 AM
66three83's Avatar
66three83
66three83 is offline
I honestly look forward to your posts, cause you're always up to sumthin!! I was actually referring to you're wanting to tinker with the brains of the transmission, your window switch fiasco, soldering drunk, now this, and who knows what else!! It's neat to read about your adventures personalizing this truck, I'm just sayin I wouldn't want it when you're done with it!!!
Carry on...
Old 01-07-2013, 10:10 AM
Izero's Avatar
Izero
Izero is offline
i don't understand how you have 3.3V at the light and not a full 12v. from the diagram i am looking at you should have a full 12v at the light socket. i think the only difference is where they get there ground connection from
Well I know on trucks with the TIPM system, the whole system sees some voltage (<=5V) for like 15-20 minutes after you turn it off...
I assume that is how it knows what circuits to turn off, for example I was working outside and needed some light, so I went and turned the headlights on and about 15-20 minutes into it, they just turned off... so I went and turned them off and on again... to my surprise they turned off again... then I remembered TIPM controls just about everything, and sure enough it says that the headlights will turn off after a period of time of the engine being turned off so that the battery doesn't get drained.
Needless to say I stopped being lazy and went and got the extension cords and work lamps after that.. lol
Old 01-07-2013, 10:36 AM
GRNDPNDR's Avatar
GRNDPNDR
GRNDPNDR is offline
Carry on...
The transmission was solved just by turning OD off.... I'm just glad I found that out before I started doing something crazy lol.
I've been like this my whole life, that's why I took engineering
One time when I was like 5 or 6 my parents bought me a remote controlled "big foot" monster truck. I had it for about a day before I decided to smash it all up so I could turn it into a robot..... I have no idea how I would have ever done that, but hey I had big ambitions lol.
needless to say my parents were less than amused.
as far as this truck or any of my vehicles are concerned, I always make sure to do the work properly.
Old 01-07-2013, 04:08 PM
66three83's Avatar
66three83
More power to ya!! I look forward to many more posts. You are obviously not satisfied with status quo, business as usual, and I commend you for that. Maybe as a result of your tinkering and schooling, you can provide a better product in the future.
Old 01-07-2013, 04:13 PM
66three83's Avatar
66three83
BTW, you must be just a few years younger than me. I had that big foot programmable truck when I was maybe 12 years. I remember I was dissapointed in the fact is wasn't 6 wheel drive, as it had 6 wheels with only 2 of them powered. I tried to tie them all together with a rubber strap. It didn't work. Keep tinkering!!!!
Old 01-07-2013, 04:18 PM
66three83's Avatar
66three83
Never mind. The truck I was referring to was Big Track. It was not remote control, you had to program it with a keypad on the top. We are not so close in age, as it came out in 1978!!
Old 01-07-2013, 04:24 PM
Izero's Avatar
Izero
Izero is offline
back on topic yet?
NEGATIVE!
Old 01-11-2013, 10:51 AM
GRNDPNDR's Avatar
GRNDPNDR
GRNDPNDR is offline
I was born in 82
Anyway I got this solved. I picked up a couple of 91Ohm 3W resistors (closest they had) and it seems to be doing the trick perfectly.
There are a couple of little "tabs" on the side of the sockets that resistors will just slide right into. Just push the socket in a bit and the resistor will fit in no problem.
they get really rather hot though so make sure they are directly under the metal heat shield, and sitting out in the air slightly.
12.3/91= 135mA dissipation
12.3^2/91=1.66W
Glad I went with the 3W resistors.
Quick Reply: Where to put resistor(s)?
