9.25 rear end questions
Old Jan 16, 2013 | 10:32 PM
joebaum's Avatar
joebaum
Yep that right there will not only fill the whole unit up with metal that takes a full day to scrub out, but will keep grinding in to the housing ( reverse side of carrier bearing cap) rendering it junk. Mine failed at around 40,000 (pathetic ). I made the tool for spanner and went with eaton tru trac. No complaints ( yet) . If I can do it anybody can ! I've got about 5,000 hard miles on it so far so good. I normally baby my stuff but when I've got to fix something makes me mad and for some odd reason ill beat the hell out of it to teach it a lesson. My tires r paying the price . Good luck . Stock LSD JUNK!
Old Jan 17, 2013 | 07:45 AM
Izero's Avatar
Izero
Can't go wrong with Eaton or Detroit rear differentials.... things are animals!
Those stupid retaining clips break all the time... I should probably have my diff opened up at my next major service to check it out....
Old Jan 17, 2013 | 12:14 PM
smamas's Avatar
smamas
Anyone know if Spicer or another mfr. makes a clutch pack with a clip that is stronger than the Mopar one? Just wonder if the stock carrier can be rebuilt with better clips/reliability.
Old Jan 21, 2013 | 08:50 AM
Izero's Avatar
Izero
no harm in calling each manufacturer and asking... but off the top of my head, I don't know of any.
Old Jan 21, 2013 | 01:25 PM
timekop's Avatar
timekop
I like the Auburn LSD I put in mine after the original retaining clips went at 78,000 miles.
Old Feb 8, 2013 | 08:44 PM
jj141979's Avatar
jj141979
tttttt
Old Feb 24, 2013 | 10:20 AM
Dutch283's Avatar
Dutch283
Default Stock Brand
Dana/Spicer is the manufacturer of the OEM LSD. I would not be surprised, that they would send you parts (for reasonable cost) if you called and told them what you were going to do. But for the cost of the rebuild, you would be better off getting a Detroit or Auburn (watch out, non-rebuildable).
Hope this helps.
Old Feb 24, 2013 | 07:45 PM
redram2007's Avatar
redram2007
Anyone have any experience or comments on the Yukon Dura Grip?
Old Feb 25, 2013 | 02:25 PM
Dutch283's Avatar
Dutch283
I have heard that the Yukon Dura-Grip is comparable to a Detroit but that is in extra heavy vehicle axles (Rockwell 2.5 Ton, 14-bolt, Dana 60HD). This info for the Yukon, I found on Steel Soldiers and the guys over there have only good things to say for the Dura-Grip and Grizzly Locker
It is cheaper, but only time will tell if it holds up as well as the "tried and proven" Detroit.
Old Feb 25, 2013 | 09:01 PM
redram2007's Avatar
redram2007
I did some research and one of the positive things i read about the dura grip is that it can be rebuilt.
