2004 doesn't run quite right
Old Jan 11, 2013 | 05:52 PM
mike_r's Avatar
mike_r
Default 2004 doesn't run quite right
Hello all, it's been awhile since i've been on, but I'm been busy with college and all. Anyways, a few hours ago I had my first major problem with the ram. It just shut down when I came to a stoplight about 3000 feet from my place. Long story short, got it back to my place and checked a few things.
It has good fuel pressure, I hear the pump, it squirts out when i hit the valve.
Air filter is not clogged, throttle body is pretty clean, it moves freely.
There are no codes.
Won't restart unless your foot is on the gas.
Won't run less than 2k rpm.
Has very little power even at 4k rpm.
I put the stock tune back on, it's been on performance ever since i've had it.
It started and ran perfect up until now. Didn't notice anything weird during the last "good" start. There was no loud clunk, no banging, it just died when it did. There is about 1/4 of a tank of fuel in it that's about 2 weeks old. Didn't have a problem with the rest of the tank.
Any suggestions would be appreciated, as i'm out of ideas at this point. My next step will be to check compression.
Thanks,
Mike
Old Jan 11, 2013 | 05:55 PM
p38251's Avatar
p38251
What engine. mileage?
Old Jan 11, 2013 | 05:56 PM
mike_r's Avatar
mike_r
2004 5.7 120k miles
Old Jan 11, 2013 | 08:13 PM
mike_r's Avatar
mike_r
Can't get access to the compression tester until tomorrow. I pulled the a plug from the front 4 cylinders and they are all golden brown. There seems to be quite a few threads on this already, but I do not see a definite solution.
Would changing out the crank sensor help?
Do these engines have cam sensors on them?
Old Jan 11, 2013 | 11:14 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Do you have a CEL light on? It could have been a fluke?
Old Jan 12, 2013 | 01:08 AM
mike_r's Avatar
mike_r
No lights. No codes on the superchips.
Old Jan 12, 2013 | 01:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Pull your valve covers and one plug from each cylinder, rotate the engine by hand slowly and watch each valve move up and down and make sure each spring is not broken
Old Jan 12, 2013 | 05:39 PM
mike_r's Avatar
mike_r
So I did some digging today, and I saw some weird stuff happening on the super chips today. I started probing the throttle body. Now according to the manual, there are 2 sensors in it. The from what I know about automotive and safety, this is because the 2 sensors need to be inverted. The trace would look like the trace image that I attached as you slowly open the throttle plate. I probed pins 1 and 4, and on 4 I got a 4.5-.5 volt reading depending on how far I opened it. I'd assume that the other sensor should read .5-4.5 as I slowly open it. I get a steady 0 across the board. That would make sense to why it's not tripping a CEL. I was wondering if somebody could go check their pin 1 and 4 on their throttle body to make sure i'm on track before I spend money on a new throttle body. I used a multimeter and paperclips to get into the holes. You only need 1 paper clip and then ground the other lead.
Attached Thumbnails 2004 doesn't run quite right-pinout.jpg   2004 doesn't run quite right-trace.jpg
